CPU doesn't turn on!!
I have a Compaq Presario SR1123WM and when I plug it in, nothing happens. The green light on the back of the tower blinks continuously.
  • Anonymous Apr 02, 2009
    maybe..
  • Anonymous Apr 29, 2009
    ok this is the second time it happens to me, the first time the computer was very dirty on the inside i took it to comp usa and they clean it on the inside with a dust remover spray, after that it worked fine. but now i was working in my hose replasing some walls, i put some new dry walls and with all the dust after i finish i whent to turn on my pc and it didn't turn on...so guys do you have any idea what can it be happening????
    Novelist:
  • 119 Answers
    • Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
      1. Disconnect everything from the computer, including the power cord.
      2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
      3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch CPU doesn't turn on!! - c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
      5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
      6. Remove all attached devices except for keyboard, mouse, and monitor.
      7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
      8. Check the power switch:
        1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
          • If the button sticks, it should be replaced or serviced.
          • If the power button does not stick and appears to be functioning, continue using these steps.
        2. With the power cord disconnected, remove the case or side panel.
        3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
        4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
        5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      9. Find the defective part:
        1. With the power cord disconnected, remove the case or side panel.
        2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference. Figure 6: Example of common power connections c00540428.jpg
        3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
          • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
          • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
          • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
          NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement. If the power supply was damaged due to power outage or storm, this may not be covered under the "act of nature" policy in the warranty statement. Refer to the warranty statement that came with your computer for more information.
Posted on Jun 20, 2008
Compaq Presario SR1123WM desktop won't turn on
Hello Kim.
When you press the power button, is there no life?
The PC may be set up for manual start instead of auto restart after power is restored.
Otherwise a surge may have blown the PSU.
Mine's not a Compaq but I'll research what the green light is.
Could be a modem....
Dec 04, 2017 | Computers & Internet
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
No Power!!
Double check the switch in the back of the pc on the power supply. If their is a switch, you can try it in both positions. It is possible their is no switch, older compaq's are iffy. The switch will be black. Also check the 110/230 switch. I don't know what country you live in, however you may need to make sure that switch is in the appropriate spot. 110 for USA and 220/230 for UK
Also, try unplugging your pc. Let it set for about 1 minute. Plug it back in and try again.
Oct 11, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
1,569 people viewed this question
David Payne
David Payne
