Question about HP DeskJet 940c InkJet Printer
HP940C cradle I recently moved and plugged in my HP 940C printer. However the cradle will not move to the left when the top lid is lifted open. There is a strange slipping noise as if it wants to move but is jammed. If i lift the cradle while pushing the middle button it will move over to the left and return to the right, but the middle light and power light will still flash. Any solutions?
  • cquinnsoutha Feb 21, 2009
    Printer has middle orange and right green light flashing. When I open the front cover and push the middle black button with the paper icon on it, catridge moves slightly out of it's home position--not enough for me to remove either catridge, then moves back to the far right out of reach. Grinding sound like it's trying to do something when cartridge is hidden out of sight.
  • jktravl Mar 13, 2009
    hp 940c printer, ink cradle is locked on the right side and will not move
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
This still current?
Posted on Aug 19, 2008
I have a HP Photsmart 8250 it is telling me that the printer cartridge cradle is stuck. I have taken all cartridgese out and in again. I have opened the back and there doesn't seem to be a paper jam. I...
on the printer if the cradle is stuck on right position disconnect the plug from the outlet then push gently the cradle to the left then plug the unit turn on if it is stuck on left disconnect the plug from the outlet then push gently the cradle to the right, hope it helps god bless
Jul 31, 2011 | HP Photosmart 8250 InkJet Printer
I recently bought an HP deskjet 810c at a yardsale-- I already have a HP deskjet 722c so I am familiar with the design. The printer seemed to react ok when I powered it up (cartridge came to the center...
Hello cmcclung147
You certainly didn' t mess up , I can assure you .
Generally , with power of and gently lifting the carriage and manually moving it from left to right and/or vice versa , plugging power back on , solves the problem . I succeeded that way with my 930C . Should work with your device .
Good luck !
Best regards ,
fanaudi .
Apr 28, 2011 | HP DeskJet 940c InkJet Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Hp 812c cartridge cradle is stuck on the right, not moving to the
unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
Feb 27, 2009 | HP DeskJet 812c InkJet Printer
The error message is ?Print catridge cradle cannot move?
Removed and realigned print Cartridge which was not firmly fixed.
Jan 29, 2009 | HP DeskJet 940c InkJet Printer
The power light and the paper light are blinking continuously.
turn off the printer open the lid move the cradle back and forth then move it to the middle, close the lid turn it on let it warm up and open the lid the cradle should move to the center, it sound like the home position senser might be going out or it is just ouot of wack.
Jan 25, 2009 | HP DeskJet 810c InkJet Printer
The cradle is stuck
Fixed it myself...found this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00738923&dlc=en&product=443024
It would print the Tap Test as instructed in this illustration....but then wouldn't move to print anything else. So redid the Tap Test several times....then I lifted the lid while printing a test page so the cartridge was in the center and I could get ahold of it to slide it....left the printer ON, but unplugged the power cable...and then I was able to move the cartridge back and forth. I then took QTips with Windex on them and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
A couple more test prints...and sliding the cartridge......and it is finally running again.
Jul 06, 2008 | HP Photosmart 8250 InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Hp 940c lights flashing
your printer need maintenance reseter
Jan 03, 2008 | Office Equipment & Supplies
Cartridge cradle stuck
Hey chips 53 Very simple, Go to the market and purchase a set of screw driver of long sleek neck (for star screw). and open the four screw present four different side in the printer. After open the screw, open that door, from where you insert the cartridge. insert your hand into the printer and lift the portion upside. Remember you have to lift equally (but slowly-slowly) if you see that the upper body is separating, you have to concentrate to lift the portion from right side because wires has been attached left side. After removing the upper portion you can easily move the carriage. And do what you want
Sep 12, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP DeskJet 940c InkJet Printer Logo
114 people viewed this question
Ben Johnson
