Question about Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB557 CESI
Flashing - F I - Locked and making a beeping noise.
This all happened after a thunder storm. Can't stop the beeping or clear the Locked code.
    President:
  • 1,314 Answers
Try disconnecting the power for 30 seconds see if it resets if it doesnt then you will have to replace the control bd how old is it
Posted on Jun 20, 2008
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
Frigidaire ples389dce
Unplug or turn the circuit breaker off to the unit for 10 minutes and retry. If you see no change then contact Frigidaire directly.
Aug 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
While baking my fridgidaire oven started beeping with the code F5, does anyone know what this means and how to make it stop?
Oven temp sensor shorted.Press and hold any key down to clear and make it stop beeping.
Feb 07, 2011 | Frigidaire Ovens
Help our frigidare double oven is locked and we cannot get the chicken out....it keeps beeping and showing an f1 symbol
Press Clear/Off to stop the beeping... then press clear/off again. If it doesn't unlock - wait about 15 minutes for it to cool down.
The F1 error means the EOC (Electronic Oven Control) board has a failure - and thought there was a run-away temperature condition.
It should allow itself to unlock after a few minutes of cool-down.
For additional help in finding a replacement part - a Model # will be required.
Thanks for using FixYa!!
Jun 26, 2009 | Frigidaire Ovens
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F2 error
what is solution
Dec 08, 2007 | Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
184 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
