Question about GE 168947 Toaster Oven with Convection Cooking
Toaster Oven 169068, can't remove burnt on grease and stain with just hot sudsy water as recommended in manual. Even the glass door can't be cleaned appropiately.
Steel wool
Posted on Jul 23, 2008
The interior of my euro-pro kitchen rotisserie convection oven model TO241R needs major soot and grease cleaning. Is there a way to clean it on high temperature setting? If not, please recommend a...
Most toaster ovens don't have a self clean function, because they are not made of the same sturdy metal that full ovens are made of. Clorox Clean-Up works pretty well if you spray it on the grime and let it sit for 5-10 minutes before wiping it away. Let it sit longer for tougher dirt.
May 03, 2011 | Toaster Ovens
Have a toaster oven broiler. Had it for years and cannot clean the glass. It looks dirty and terrible all the time. Helene
Hi Helene, Welcome to FixYa. I am Kelly
There are 3 ways we as service techs use on a stubborn glass that is badly stained to get them clean.
1. On a warm not HOT oven. Spray it with "easy off" oven cleaner on the glass only and leat it soak for about an hour. I use thick stacks of newspaper for maksing off the metal while applying the cleaner so as not to get the easy off oven cleaner on the metal. I lift away the newpaper after the application. Then at the end of 1 hour wipe it off. Do a second treatment if necessary.
2. If after the Easy Off cleaning periods you still have the stained glass make a trip to any auto parts store and buy some engine degreaser. (Aerosol) Do the same thick newsprint masking routine as above and lift it off after application. Let it sit for an hour and wipe off with paper towels.
Do a 2nd treatment if necessary.
3. Next to last cleaning use Mr. Muscle Kitchen Cleaner on everrything in the broiler. No masking required. Spray it on... let it sit at least 15 minutes and wipe clean.
Final cleaning use a mild dishwashing soap and water. Then do a fresh water wipe off. Make sure to remove everything you applied as it WILL make your broiler smell bad if you don't get it all off.
Thanks for choosing FixYa,
Kelly
If you would please.... do post any feedback good or bad after you clean the glass and broiler oven.
Oct 06, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
you can get the new elements from the online sites mentioned below www.repairclinic.com also from www.partsselect.com and for cleaning follow this instructions
  1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
    2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
  2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
    This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
How to remove grease splatter from toaster oven
set a bowl of ammonia in it over nite. do not turn oven on the fumes will ease the grease off. wipe clean in the morning with a dry cloth
Sep 18, 2009 | Oster 6058 Toaster Oven with Convection...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
GE 168947 Toaster Oven with Convection Cooking Logo
190 people viewed this question
Top GE Toaster Ovens Experts
Mack Baxter
Tom Chichester
Bill Boyd
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
