Question about Dryers
How to change rollers on an older maytag dryer
  • 525 Answers
I have inserted a link that shows an expolded view of a Maytag dryer. This may aid you as you progress through the disassembly of the dryer.
1. Disconnect the power from the dryer.
2. Remove the front panel.
3. Remove the drum bulkhead
4. Remove the drum belt by releasing the tension on the idler pulley.
5. Remove the drum.
6. Remove the TRU-ARC snap ring clipped to the front of the roller shaft. It looks like a C with 2 small holes in each end.
These rings require a special TRU-ARC plier, or use a butter knife or a putty knife, instead to pry the rings off.
DO NOT misplace the snap rings.
7. Remove the rollers, clean the shafts, or replace if too badly scored, lubricate with poly-lube, and reassemble.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
Replace Roller on MCG5500AW
if you already got into the dryer and are at the rollers all you need to do is remove the front clip with a needle nose plyers,the blades have to be thin enough to fit into the two holes on the clip,spread the clip open just a little,enough just to remove it,then slide the roller off, remove the old washer on the shaft,sand down the shaft and then slide the new washer on then the new roller,another washer and then the clip,you don't have to remove the back wall to change out the rollers.roller part number is 12001541
Jun 11, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Screaming sound when dryer is on
Hi, W/D here.
Screaming dryers can usually be traced to the drum support roller and the roller shaft. Once the screaming has commenced, both parts usually are damaged beyond reuse. Check this link; it will give you a good idea of what you need, and what to look for. You can scroll over the diagram to view the parts and assembly instructions. A lot of information, if you need it. It will be best to use tha diagrams as a disassembly guide, and confirm that the roller and roller shaft is the issue. Since you're already down to the rollers, it would be wisest to change them both at the same time, if this is the issue.
Best regards, --W/D--
Feb 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My older maytag dryer runs very slow,sould like
the rollers might be out. or the bulkhead is worn
Feb 06, 2010 | Dryers
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
Hope this helps
Sep 29, 2009 | Maytag Dryers
Help Changing Belt on Maytag PYET444AYW dryer
Normally if it is a front loading machine then you need to take the front of the dryer off.
This will expose the drum, roller, etc.
Remove the drum, install new belt on the motor pulley, loop around the idle arm roller, then install on the drum and reinstall the drum, reinstall the front and job complete
Sep 26, 2009 | Maytag Dryers
Maytag makes clunking sound
one of the rollers is bad and needs to be changed
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
183 people viewed this question
Top Dryers Experts
