Vacuums Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I am looking for the schematics for an electrolux 2100 canister vacuum?
Roger Potts
Level 3:
  • Master 694 Answers
  • Posted on Nov 18, 2010
Roger Potts
Master
Level 3:
Answers
694
Questions
0
Helped
220307
Points
1873
Schematics and repair manuals are only available to authorized Aerus Electrolux service techs. They no longer print the manuals, instead making them available through software, again only available to the computers at the Aerus stores.
The reason for this is obvious. Making them available to the general public would mean less work for the techs, thus less money for Aerus.
Where are locking keys on old electrolux canister vacuum #2100?
not sure what you mean, I assume you are trying to access the inside.Oneach side of the machine there are sliders. The long rubber deal on the sides.Theses slide out..be careful and make sure the machine is unplugged....
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
I need a new power cord for the power nozzle on my Electrolux 2100 canister vacuum. The power nozzle has part number N115M written on the bottom. I have found the power cord for power nozzles PN6 and PN7...
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
http://www.aerushome.com/storelocator/
10helpful
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
I need to find schematics for el7055b
Here's a parts schematic of the Electrolux EL7055B that you requested. If you need to purchase a part for your vacuum, and are not able to find it listed anywhere online, please feel free to contact us, we have access to every part for your vacuum cleaner.
http://lib.store.yahoo.net/lib/a2zvacuums/EL7055B-parts-schematic.pdf
I hope that this information is helpful. If it was, please be sure to rate the repair has helpful by clicking the thumbs up icons in the top right hand corner of the repair.
Thank you,
Chris J.
GoVacuum.com
1helpful
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 • Vacuums
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
2helpful
2answers
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
5helpful
2answers
Replacing on/off switch of electrolux
In yhe side of you canister there is a ruber molding on each side. Open the door to access the bag and you will be able to pull these two molding straight out this will allow you to split the canister.
Apr 24, 2008 • Vacuums
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
