Question about Denon AVR688
Connecting DVD player to AV receiver
Hello Jaime867,
I've been trying to connect my DVD player to my new Denon receiver (AVR-687) through a digital cable for a couple of weeks now. The audio works fine through RCA cables but when I try to use a digital cable - nothing. Until today I only had two front speakers but today I got a center channel as well as surround speakers and next week I'm picking up a sub. Again today I tried the optical cable and no sound. I have the input setting on Auto and I've tried assigning both optical 1 and 2 as well as the coaxial cable inputs but again nothing. When I did a tone test all the speakers seemed to be connected correctly. Do you think I need to take the item back or am I missing something in the manual? Any help or suggestions would be greatly appreciated.
Cheers,
reggae40
  • reggae40
    reggae40 Jun 20, 2008
    Hello Jaime,
    Thanks for the quick response. I have checked the page in question (numerous times) but I still can't understand why I'm not getting any kind of digital signal. I've tried both optical inputs as well as the coaxial ones.
    Cheers,
    reggae40
  • Jaime Hernandez May 11, 2010
    Have you check the user guide on page # 41?
  • 2,322 Answers
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Posted on Jun 20, 2008
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
Connecting two mulitchannel devices into one receiver
I guess you could try y cable adapters for input on the Denon. Might get messy. Try radio shack and pick up 5 y cables for the speakers and 1 for the sub. Someone probably makes an audio switcher that handles that as well.
Mar 22, 2009 | Denon AVR-4802 Receiver
Need help connecting PS3 to my Denon AVR-3801
You could try sticking a vcr/dvd player in between the connections and using those input/outputs instead.
Dec 31, 2008 | Denon AVR-3801 Receiver
DENON AVR-3801 Digital problems
Check with DVD Player settings.
Jul 20, 2008 | Denon AVR-3801 Receiver
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
Denon AVR688 Logo
498 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
