Replacing backlight inverter board
I read your post about replacing the backlight inverter board, but when i searched for one online, I got a headache. I have a magnavox 32" lcd tv model#32MF605W/17. I wanted to make sure that i got the correct board, but i keep getting products that are "backlight inverter" (w/ no "board" in the description.) or results denoting the part as a master or slave. any information that you could supply me with would be greatly appreciated. Thank you
  • Anonymous Mar 26, 2014
    DOES NOT TURN ON BLINKING BLUE LIGHT HAVE RESET TO RED START LIGHT...i HAVE REPLACED POWER BOARD, OLD BOARD WAS READING 56VOLTS SUPPLING THE INVERTOR BOARD..IT NOW READS 24VOLTS WILL NOT TURN ON..???REPLACE INVERTER BOARD...thanks for any help rick
  • 44 Answers
Not always but usually the inverter board is part of the display panel, way to much money to bother fixin.
Posted on Jul 03, 2008
Thanks everybody for your help. I replaced the main Board and that solved the problem.
Posted on Jan 04, 2012
On this model there are two backlight inverter boards (also known as simply backlight inverters, they are in the form of PC boards) - one is a master and one is a slave. I have this very TV, with symptoms similar to a backlight inverter problem, however, I believe in my case I have a bad power supply.
Posted on Sep 21, 2009
I have backlight issue in my tv...i take flashlight test...so there is video but no backlight...samsung 32inch led tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 02, 2016 | Televison & Video
Right side backlight screen is dark
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 25, 2015 | Vizio XVT3D554SV 55 Full Array LED Full HD...
LG 50LN5700 TV. Why does it have a picture but no backlight?
May 19, 2015 | LG Televison & Video
Backlights not coming on in samsung led tv
Back - light problem? Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Apr 13, 2015 | Samsung Televison & Video
The picture on my LED TV went out abruptly and wont come back on. I'm getting sound, but no picture, besides replacing the LED driver/power board (I did), what can be done to fix it?
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 12, 2015 | LG LN5100 50" LED TV 1920x1080, 60 Hz,...
Has sound but no picture
Backlight problem. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Jul 01, 2014 | Insignia Televison & Video
Sony lcd tv not pwering on
After replacing the main board, a software update should be done. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Sony KDL40EX400 40 inch BRAVIA 1080p LCD...
Gateway inverter board replacment
The inverter board is the circuit board inside the screen, with all the capacitators etc that controls the backlight. It looks like this:
http://cgi.ebay.com/GateWay-7322-7330-7340-7410-Inverter-83-120082-3000_W0QQitemZ290289050786QQcmdZViewItemQQimsxZ20090114?IMSfp=TL090114125004r29293
You can just google 'changing inverter board gateway' and see if you can find the closest guide to your model..
I found this one 4th on the list..
http://www.pcgeekdom.com/2006/02/replacing-laptops-lcd-backlight.html
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Gateway 7322GZ Notebook
Televison & Video Logo
3,914 people viewed this question
Top Televison & Video Experts
