Question about Gateway 7330GZ Notebook
Looking for parts
I need the little ribbon cable that connects the on button (and other buttons) to the motherboard. I also need the little connector thingees that hold the ribbon in place. Anyone know where I can get these items?
    Genius:
  • 2,028 Answers
Your best bet is Ebay. That's where I get most of the small parts I need. If you can't find the exact part, look for a machine that doesn't work. Sometimes you can pickup a whole machine with a bad motherboard or other major issue cheap. Then you have several spare parts for your machine.
Posted on Jun 20, 2008
Only the plus button on console works nordictrack c900i
Most buttons (all but incline 6 through 12) on my C900i stopped working all of a sudden. Long story short... it was the ribbon cable connections on the back of the control panel. Its 6 screws to get the panel off, and then 10 screws to open the panel. Cut the zip tie so the connection wires can be pulled through the hole in the back panel cover. And then take the iFit module off after you open the panel to allow fully removing the cover. The little white piece on the ribbon cable connectors slides up to allow the cable to slip out. Search youtube if you've never dealt with ribbon cables/connectors - they're very common in electronics. You can also search for how to clean the cables. In my case, simply disconnecting/reconnecting was all I had to - this fixed every button on my panel.
Jan 27, 2014 | Nordic Track NordicTrack C900I TREADMILL...
Hp8710w
Have it checked in service. This could shortcircuit the display and burn it
Oct 12, 2012 | HP Hewlett-Packard Compaq 8710w Mobile...
Pulled out media bar ribbon cable along with connector
Then fix it without there help,
if you are able, get your manual if you can, it may show you how.
But i doubt it, they dont want people messing about inside laptops, there are no/or very little user servicable parts in there
Jul 17, 2010 | Gateway P7908u FX Notebook
How do I remove the keyboard from a Advent 7109B laptop, in particular the ribbon cable.
The ribbon cable is connected to the motherboard by either of these two methods.
The ribbon cable has a connector attached to the end of the cable and it fits into a socket on the motherboard.
OR
The ribbon cable just slots into a connector on the motherboard. To release the ribbon cable lift the locking bar up on the motherboard connector and the ribbon cable will be released and slip out easily.
To insert the cable back into the connector, lift the locking bar up, insert the ribbon cable into the connector as far as it can go and push the locking bar down to lock the ribbon cable onto the connector.
Mar 30, 2010 | Computers & Internet
Acer aspire one mouse pad clicks not working stuck on right click
If you are saying the right button is down and is not coming back up, then either the plastic lip on the button is jambed against the palmrest, or the actual mechanical part of the mouse button underneath has collapsed and has become non-functional. If the right button clicks but does not do anything like bring up the selection window in windows then that may be a hardware issue related to XP, try this, go to the control panel > system > hardware > device manager> scroll down the Mice and pointing devices. Highlight the touchpad and click on uninstall. Make sure you are connected to the internet when you reboot and have your usb mouse hooked up so it is easy to work around this. When windows reboots it will be forced to reinstall the touchpad because it will recognize it as a new device and want to install drivers for it. If it asks to search windows update for a fresh driver, allow it and let it finish the install. See if that corrects the problem. If it is mechanical in nature, then the palmrest is going to have to be taken off and the touchpad button assembly underneath replaced.
Oct 06, 2009 | Computers & Internet
Fujitsu N6010 Power Button Cable Disconnected
it's just a typical ribbon cable... they plug into a slot. the slot may have a "hinge" like thing your have to carefully open.. or it may just be you have to plug it in to a "****"
I don't have a Fujitsu, so I can't tell you how exactly, but with Dell's the ribbon cable doesn't always have an "end", the "end" may be part of the motherboard.
this probably didn't help you, but thought i would give you some insight
Sep 15, 2009 | Fujitsu Siemens LifeBook N6110: Intel...
Replace the keypad on a palm centro
first off you need a t6 screwdriver. this is a special screwdriver with a star shaped bit specifically used for the screws in your centro. if you don't have one, you can buy one off ebay cheap or maybe even borrow one if you go into your local cell phone shop. they probably could even help you replace it if they're nice, even if you didn't buy the keypad from them.
start by taking out your stylus, your battery, and the little rubber plug thing on the opposite corner from your stylus. it just kinda pops out if you get under it with something pointy like your nail. set these things aside somewhere safe. there are six screws to take out, one under where the stylus was, one under where the rubber bit was (there are three holes here, the middle one is the screw hole), and four more that are super easy to see with the battery cover off. take out all six screws and put them somewhere safe too. then gently pry the back housing up from the bottom and pull it downward with a little wiggle and it will come right off. there is a smaller separate piece that surrounds the hotsync cable port and charger port and this comes out too. set these aside.
the next piece we will take out is the motherboard. you will need to disconnect the screen and the keyboard. they are actually under the motherboard but connect to the top side. lay your phone facing down on the surface in front of you and there will be two pieces of black tape toward the bottom of the exposed motherboard, one on either side. gently pry them up, folding them back toward the edges of the phone but do not remove them completely. this makes it easier to replace them later. under the tape are connectors for the ribbon cables that connect the screen and the keypad. there is a small grey bar that locks the ribbon cable in place. gently pry them up, flipping them toward the center of the phone. then gently pull the end pieces of the cables out of the connectors. they will kind of just point up toward you, not flop back over the edge of the phone.
lift up the motherboard by the bottom, like where the hotsync cable goes. pull the motherboard down toward the bottom of the phone while gently (or it will break off) lifting up the part of the housing that covers the speaker and the camera. set the motherboard aside.
now there is a kind of sticker that looks like gray mesh covering the back of the screen and the keypad. pull this up gently from the bottom wherever you can get an edge started to pull it up. you can stop pulling when you get to the part where it's just covering the back of the screen because you won't need to get under there. the flat ribbon cable that goes to the screen might stick to the mesh, and that's ok, just push the whole thing up out of the way.
now you can lift up your phone and gently push the keyboard back through from the front. it will kind of pop out. it helps if you hold the phone facing down still and use your thumbs to kind of push the sides of the phone out a little so the keypad can just pop back. at this point you should have the part that is the keyboard with the cable sticking out of it, and if this is the part you need to replace, ignore the next paragraph. if it's the actual arrow and power keys, read on.
the green and red buttons (or power and talk) and the 5-way navigation button are all connected together and you can replace this whole piece by just pushing it out from the front, and setting the new one in it's place. it's easy to get mixed up, so just in case, the green button is on the left front and the red button is on the right front.
now there's just putting the phone back together. pop the keypad back in (check the front to make sure it looks right and it's popped in all the way). re-stick the mesh back down over top of it. make sure you have both cables showing and they didn't get stuck under there. take the motherboard and slide it back under the speaker cover (lift it up and wiggle), and make sure the cables don't get caught under it. it takes a fair bit of wiggling to get it sitting in there flat. reattach the cables by sliding the ends into the little slot. if you look carefully, there are little guide lines on the keypad cable that come just to the edge of the connector when it's all the way in. flip the little gray bars down to lock the connectors in place and restick the tape. put the little plastic piece from the bottom back on (it only fits one way) and then put the back housing on and push on it until it kind of clicks into place. replace all the screws, the stylus, the battery and the cover. you're done!
May 13, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Packard Bell Imedia 1402 wont boot up
you did not install the new Hdd properly, the part of the ribbon cable with colour should be by the side of the power connector and the power connector should be connected with the red cble by the side of the colour on the ribbon cable.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 03, 2007 | Computers & Internet
GE Oven JKP15
it is the connector for the ribbon cable on the back of the control panel. I bought a new panel as well and figured out it is the ribon cable connector in the back doesn't hold the ribbon well . I am looking for the part to replace it on line with no luck yet ( the whole board area is 178.00 us dollars so i just want the 5 dollar or so ribbon cable connector to soder in.
Jun 10, 2007 | GE Profile JK915 Electric Single Oven
Gateway 7330GZ Notebook Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
