Question about Frigidaire Kitchen Ranges
We have the cleaning feature on. We have lost our manual and don't know how to turn it off. It has been on for over 3 hours. Can you help?
    Genius:
  • 2,035 Answers
Please unplug the main cable or switch off the mains to turn off the unit .please provide model number of the unit..................
Posted on Jun 20, 2008
  • Anand Kumar
    Anand Kumar Jun 20, 2008
    Stopping or Interrupting a Self-Cleaning cycle:
    If it becomes necessary to stop or interrupt a Self-Cleaning cycle
    due to excessive smoke or fire in the oven:
    1. Press Clear/off.
    2. Once the oven has cooled down for approximately 1 HOUR and
    the "DOOR LOCKED" icon is no longer displayed,the oven door
    can then be opened (Fig. 7).
    Fig.7
    When the Self-Clean cycle is done:
    1. The time of day,"DOOR LOCKED" and "CLEAN" icon will remain
    in the display.
    2. Once the oven has cooled down for approximately 1 HOUR, and
    the "DOOR LOCKED" icon is no longer displayed, the oven
    door can then be opened.
    IMPORTANT NOTES when using the Self-Clean feature:
    1. The Self-Clean feature will not operate whenever a radiant surface remains ON.
    2. A Self-Clean cycle cannot be started if Oven Lockout feature is active.
    3. If a Self-Cleaning-Cycle has started but not finished and a power failure occurs, the appliance may not have thoroughly
    cleaned. Once power is restored, the Cooktop will remain locked. To unlock the cooktop press and hold the pad for 3
    seconds. The red cooktop lock icon will disappear from the display. Then set for another Self-Clean cycle to finish.
    4. If your clock is set for normal 12 hour display mode the Delay Self-Clean cycle can never be set to start more than 12
    hours in advance. To set for a delayed Self-Cleaning cycle 12-24 hours in advance see page 15 for instructions to set the
    control for the 24 hour time of day display mode.
    Genius:
  • 1,142 Answers
Unplug the power cable from the wall that will shut down the range.
  • Maanita Chadha
    Maanita Chadha Jun 20, 2008
    Provide me the complete details like the make and the model # ill get the manual downloaded for you.
  • Maanita Chadha
    Self-Cleaning Oven
    A Self-Cleaning oven cleans itself with high temperatures (well above cooking
    temperatures) which eliminate soils completely or reduces them to a fine
    powdered ash you can wipe away with a damp cloth.
    Adhere to the following cleaning precautions:
    • DO NOT use oven cleaners or oven protective coatings in or around any
    part of the Self-Cleaning oven.
    • DO NOT clean the oven door gasket. The woven material of the oven door
    gasket is essential for a good seal. Care should be taken not to rub,
    damage or remove the gasket.
    • DO NOT use any cleaning materials on the oven door gasket. Doing so
    could cause damage.
    • Remove the broiler pan and insert, all utensils and any aluminum
    foil. These items cannot withstand high cleaning temperatures.
    • Oven racks do not have to be removed. If they are not removed during the
    Self-Clean cycle their color will turn slightly blue and the finish will be dull.
    After the cycle is complete and the oven has cooled, rub the sides of the
    oven racks with wax paper or a cloth containing a small amount of salad oil
    (this will make the racks glide easier into the rack position).
    • Remove any excessive spillovers in the oven cavity before starting the
    Self-Cleaning cycle. To clean, use hot, soapy water and a cloth. Large
    spillovers can cause heavy smoke or fire when subjected to high
    temperatures. DO NOT allow food spills with a high sugar or acid content
    (such as milk, tomatoes, sauerkraut, fruit juices or pie filling) to remain on
    the surface as they may leave a dull spot even after cleaning.
    • Clean any soil from the oven frame, the door liner outside the oven door
    gasket and the small area at the front center of the oven bottom. These
    areas heat sufficiently to burn soil on. Clean with soap and water.
Directions on how to use the self-cleaning feature of my Kenmore Ultra Bake Self Cleaning Super Capacity oven
First take out the racks (unless they are coated with the same porcelan coating as the oven interior). Press the Clean or Self-Clean button. Press up or down arrow key - 3:30 will show in display which represent time in hours and minutes. You can press the up arrow key for more time, or the down arrow key for less time, but usually the default time is good. Then just press Start. The door will lock and the oven will turn on. In 3 1/2 hours the oven will turn off, but the door won't unlock for another hour.
Sep 09, 2014 | Kenmore Kitchen Ranges
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Lost manual and do not know how to use my self cleaning oven. It is a whirlpool. (I don't know what model). What do I set oven on and for how long? Please give me some instructions to use the...
On the front of the oven there is a lever.That is the lock.Lock the oven and then set the temp to clean.Some will lock only when the cleaning starts,others need to be locked first.Try it both ways.
Jun 18, 2011 | Home
I have lost my book, and need to use the self cleaning oven feature. What is the process?
The oven should have a self cleang button, just remove the oven racks, because the heat will turn the shinny racks to a dull shine, and press the self cleaning button, it will go through the cleaning cycle, the cycle takes about 3-1/2 - 4 hours
Oct 30, 2009 | Ovens
Don't know how long to run self cleaner
It depends on how dirty it is. But usually 3-4 hours should do. After its done just wipe the leftover burnt pieces out.
Nov 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
46 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
