Question about Char-Broil CharBroil 4637318 Grill
We bought our grill last summer and it worked fine. When we got it out of the garage this summer and replaced the gas, it wouldn't start. We can smell the gas so we know it is reaching the burners.
    Champion:
  • 254 Answers
This sounds like an ignitor problem to me. You could replace the ignitor or you could light with a match. Most of these grills have an access point usually on the right side to light the burners with a match just make sure you light the match first and hold it into the access point before you turn the gas on.
Posted on Jun 25, 2008
I have not used my endless summer patio heater since last fall. I bought a new tank of propaned, cleaned out the cobwebs checked all connections and tried to light up the heater. It does not work. I can...
Mike, the problem started when you turned the new tank ON. But, it is correctable most of the time.
Turn the LP tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Open the gas valve VERY, VERY, SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the pilot and hold the gas control valve in for 30 seconds to 1 minute. Release the control valve and turn it to the ON position. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve on Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the heater's Hose/Regulator Assembly. A gas Grill's Hose Regulator Assembly should work and you can purchase one from any hardware store of home center that sells grills & accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 18, 2011 | Endless Summer Heating & Cooling
Runs fine until I engage the PTO and am on a slight incline.Starts to spit and sputter and cut off. Checked Plug Gap, Magneto Gap. Worked fine last summer. All I did this time was replace the blades....
check your fuel lines for clogging if it ran fine last year means you have a clogged fuel line somewhere or the carb itself is stopped up disassemble the carb and do a visual inspection also use B12 chemtool carb cleaner use both the spray and the fuel cleaner treatment i know for sure your problem is related to ethanol fuel hope this helps good luck and always run your equipment completely out of fuel for long term storage or between seasons
Apr 07, 2017 | Mtd Garden
Oil leaking from under the exhaust mower has been
souds like the carb needs cleand out it has stuck open and let the gas run in to the moter
Nov 05, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Finding a main gas valve for the Jenn-Air/Nexgrill 750-0142
i need to see a picture i may have a valve to fit mlmatthews32@sbcglobal.net
Aug 11, 2009 | Grilling
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
When i tried to start my weber q after the winter i put the dial to start and pressed the button it clicked but wouldn"t start i had put a new tank on. my e-mail is debbiedowney3@hotmail.com
Do a few things, check that there are no gas leaks (soapy water) can help. if there are no bubbles, at the valve where you attached to the tank. shut the tank off wait 1or 2 minutes then slowly open the LP gas cylinder. try to start the grill. If nothing shut the gas off and check the flame grids for water,spider webs, or holes clogged with fat and filth. Also check the igniter for spark, dead batteries or bad connection at electrode may cause it to fail.
Apr 26, 2009 | Weber Q Grill
Grill won't light. We press ignitor switch, and nothing happens
Have you replaced the ignitor? Also check the spark and make sure that it is sparking where the gas is coming out
Apr 24, 2009 | Kitchen Ranges
Char-Broil CharBroil 4637318 Grill Logo
231 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
