Question about Philips Televison & Video
I connected my Philips DVDR 3576H to my Sony Bravia TV and it looks like connection doesn't work. I used cables provided by Philips but I can not get access to this empty channel, on which I could get the picture thru the DVDR. Please help
  • 8,596 Answers
The source is E1, unless you are trying to display something froma camcorder or security cam.
Philips does not provide enough cables with this product - they only provide you one set with which to PLAY a movie. You will need another red, white and yellow cable with which to RECORD. If you have a cable/satellite box, connect a 2nd red, white and yellow cord from cable box OUT to Philips AV IN. Switch the SOURCE on the Philips remote to E1, and your TV to whichever source you have the original red, white and yellow plugged into. You should get picture, and be able to record now.
Posted on Jun 20, 2008
Connections
I believe that you simply need a splitter from your cable line from the wall to the items that need it.
That will give you input to the DVD-R and to the Cable box.
Let me know if we need to discuss further, I will be glad to help!
Brian
Aug 04, 2008 | Televison & Video
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
Cant connect my acer aspire 5334 to sony bravia tv
Your laptop and Sony Bravia LCD tv has the VGA connector.
It looks like ..
Connect your laptop to Tv using vga cable.
Thanks for using FixYa.
May 23, 2011 | Computers & Internet
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do I connect a desktop to a Sony Bravia LCD TV?
hi
u want a tv tuner contact ur pc customer care itself they will only provide  u..it will cost some
Feb 14, 2009 | Sony Bravia KDL-32N4000 32 in. HDTV LCD TV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
