Question about Toshiba WRC-1000 Router (PA3227C1ETC)
Port forwarding I need to know how to open the ports for the xbox 360 with the toshiba 1000 router.
  • Toshiba Master
  • 6,487 Answers
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
My xbox 360 is saying i have a srict nat type how do i get it to open?
You may want to turn on port forwarding for your xbox (This article explains how to do it....keep in mind, the settings are different for different routers: http://www.pctechbytes.com/gaming/xbox-360-port-forwarding
If port forwarding does not work you may want to add your xbox IP address to a DMZ in your router (again the settings are different for every router, but your router's manual should have how to do it)
Good Luck.
Mar 09, 2011 | Computers & Internet
Im trying to connect to live and I connected to the internet but not xbox live
Xbox live requires some ports to be open on your router. Make sure the following ports are forwarded through your internet router to the IP address of the Xbox.
On Xbox's site below they have some instructions for the most common router manufacturers.
From the Xbox website: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/xbox-kb.aspx?kbid=908874
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
Mar 03, 2011 | Computers & Internet
Xbox 360 nat type is strict, how do you fix it
In your Router's administrator configuration, find the UPnP setting and make sure it is enabled.
If this does not fix it, you will need to open ports in your router. You'll need to open the following ports and forward them to your Xbox's IP Address:
  • Port 88 (UDP)
  • Port 80 (TCP)
Jan 24, 2011 | Microsoft Xbox 360 Console
My nat is moderate. how do i fix it to make it more open
You can simply forward ports. I believe you are using XBOX 360. Here are the ports that you need to open
3074 TCP
3074 UDP
88 UDP
80 TCP
53 TCP
53 UDP
You can open those ports using your router's Port Forwarding feature. To know more about portforwarding, you visit www.portforward.com
Oct 23, 2009 | SMC Barricade SMCBR14UP Router
Firewall settings blocking internet from Live. I know which ports need to be open, but i dont know how to open them (I have a U.S Robotics router)
You must do port forwarding now to resolve the firewall problem. Call xbox on what port you must forward on the router's admin page for the xbox live. If I remember it correctly, xbox live uses port 3074 TCP and UDP, 88 TCP and UDP, 53 TCP and UDP, 80 TCP and UDP
May 07, 2009 | Microsoft Xbox Live Three Month Premium...
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Hi i have a satellite internet provider and im trying to set up my linksys broadband router so i can hook up my xbox 360 my problem is everytime i hook it up im getting no internet connection can you tell...
hi,
there are two things to be addressed in this case.firstly you have a satellite internet provider which can create consistency issue.then when you connect a xbox to router you need to do a port forwading on linksys router(port forwarding=opening ports in router so your xbox can communicate freely).in order to do the port forwarding you have to log onto router user interface.then go to applications and gaming tab,where you can do the port forwarding.
but before doing so,you have to contact microsoft to know the ip address assigned to the xbox and the ports(numbers) to be opened.
thank you.
Nov 27, 2008 | Linksys Wireless-G Broadband Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Opening ports strict nat
The ports will need to be opened in your router, you can also try enabling DMZ
Read this microsoft page, it tells you the ports that need to be forwarded on the router
http://support.microsoft.com/kb/908874
Please read the documentation that came with your router to figure out how to enable port forwarding, if you don't have a hard copy of a user manual, it should be included on a CD and its also available online.
Thank you,
I will fix it!!
Nov 14, 2008 | Microsoft Xbox 360 Console
Toshiba WRC-1000 Router (PA3227C1ETC) Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
