The universal remote control no longer works to control the television. New batteries were put in and still nothing
  • 8,596 Answers
We really need the model and manufacturer of the universal remote. If it is a Philips, press Codesearch and re-enter the right code after inserting the new batteries.
For other models, the codes might be here:www.tvcodes.com
Posted on Jun 20, 2008
New universal remote will do nothing, I cannot even accomplish step one. Why?
Universal Remote Not Working - Cable One
support.cableone.net/app/.../a.../universal-remote-not-working
Cable OneEven if lights on the remote control are turning on, weak batteries may still cause ...Step 6: If these buttons do work, the remote control may need to be replaced.
Repair your remote controls - Instructables
www.instructables.com/id/Repair-your-remote-controls/
InstructablesYou do not need much experience in electronics repair to repair a remote. ... On a newLED, one lead is longer than the other; that's the positive (hot) lead. ... You may find that this fixes stubborn remotes where nothing else does :-) ..... Sometimes even after thorough cleaning, I still find some buttons not functioning and have ...
Logitech Harmony Elite remote control review - Tec
Dec 29, 2015 | Westinghouse Televison & Video
I have a UMC TV /DVD Combi the remote control i got with it no longer turns the TV on or off, so i bought a universal remote and it cant seem to find the code for the remote so i was wondering would anyone...
First of all, did you put new batteries in the remote control?
That usually solves the problem, because when the batteries get weak
the output infrared signal also gets weak.
With a new universal remote control, there is a booklet containing the
codes to use for many different TV receivers. If your specific TV model
is not listed, try using one that appears to be similar to it. If that does
not work, try turning your TV on with the new universal remote. If you
can turn it on, then you may be able to have the universal remote
program itself by interacting with your TV. Turn it on and hold the
remote so that it points to the TV set and hold it there for about 30
seconds. Then try turning the TV off and on again and try to use
the channel change feature. Try this a few times to give the TV and
the remote a chance to talk to each other. Keep the remote pointed
toward the TV.
Aug 29, 2011 | Televison & Video
My remote control to my television (DS25204 Model) does not work. I have changed the batteries and nothing!!! I even purchased a universal remote ($5.00). I'm not sure if I put the code in correct, but...
Usually a new remote will do the job but you should double check to see that there is nothing blocking the receiver sensor on the TV (maybe a family picture) if this is a TV on a stand as opposed to wall mount. Otherwise check the code and procedures for programming the remote.
Jan 22, 2011 | Televison & Video
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Oct 12, 2010 | Sony KP-61HS30 TV
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My remote control no longer works, even with new
First, test that the remote is actually working. The easiest way to do this is to point it at a switched on digital camera and look at the camera display. The remote uses infra red light which the human eye cannot see, but digital cameras can. As you press a button on the remote, you should see a glow coming from the remote in the camera display.
If it is working, it is probably a fault in your TV - not a DIY fix so take it to a repair shop.
If it isnt working, you'll need a new remote. A genuine Panasonic replacement will be expensive so you may opt for a universal one. However, universal remotes wont support all the functions the genuine one does.
Your choice !
Nov 02, 2009 | Televison & Video
Remote Contol will not work, though batteries are new and red light is blinking
if it is a universal remote just look up your t.v. in the instuction book that came with the remote,and follow the instructions in the book on how to put in the code for your t.v.
Jun 03, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
