Question about LG WM3431 Front Load Washer / Dryer
Not working at all
There is a so called brand new LG WM3431 in my new apt. the hot/cold water tubes are correctly connected, and the power cord too. the machine can be turned on/off, and it works find when changing washing/drying choices. but the problem is, the machine won't start when I press the start/pause bottom. the screen on the right hand top shows "dE". I don't know what is the problem with the machine...
    New Friend:
  • 60 Answers
DE stands for "drain error". The first thing the washer always does when started is run the drain pump for 2 minutes. If somthing is jammed in the drain pump (paperclip, bobbypin,) then the motor can't run and you get the error. Also if the drain hose is blocked or the boot from the bottom of the tub to the drain pump assembly you get the same thing. Check the filter basket (behind the door in the lower left of the front).
Posted on Jul 29, 2008
  • 489 Answers
The door latch is not working properly.  You will need to have this serviced by the manufacturers warranty.
Posted on Jul 23, 2008
Lg tromm washer what does IE stand for?wash machine stops running and IE appears
LG's 'IE' stands for (water) 'Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 04, 2011 | LG WM2688HWM TROMM SteamWasher
Brand new delta roman tub faucet. Cold works great and hot side is anemic. All new pex tubing feeds it. When I got it out of box both faucets worked counter clock wise to open hot was anemic then. I pulled...
Cna you remove water line feeding hot side to make sure it has correct flow. It could have something blocking inside of water line. And check hot inlet side on faucet to make sure it is open and not blocked.
Remove line you can run water in a bucket to ensure that hot side water line has no blockage in it and have someone help you with turning water off and on for you.
Jul 31, 2011 | Delta Plumbing
I have a lg wm3431 and it does not dry i get and error code of dhe every 10 minutes is it expensive to fix?
The dryer heater is not working. You will need a technician to diagnose this problem. It is possible that the condensate tube and 2 thermistors are clogged with lint debris and will need to be cleaned out.
Good luck
Jun 15, 2011 | LG WM3431 Front Load Washer / Dryer
Can i run new hot water return line back to hot water system
Open following link to view how recirculation system looks:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Ordinarily the cold water line is used to complete recirculation loop.
There is no reason why you cannot run separate line back to water heater instead of using cold water line.
The Grundfos system comes with crossover piece that connects hot-and-cold lines at furthest faucet.
Instead of connecting between hot-and-cold line, simply connect hot to your new hot water return line.
When your new line arrives back at water heater, it must connect to cold water inlet so return water is directed to bottom of water heater.
For critical safety concerns, do not remove TP valve to install new water inlet.
Nor is it best to use extra plug on top of tank to install new water inlet, unless you also install dip tube that directs water to bottom of tank.
http://waterheatertimer.org/How-it-works.html
In the case of tankless water heater, return line must be connected to cold water inlet also.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Washing Machine not draining at all
either the pump is not working, when switched to drain do you hear a noise if not the pump not working if so then likely a blockage check filter, outlet hose and stanpipe
Mar 30, 2010 | LG WM3431 Front Load Washer / Dryer
I dont know what the piece is called but it goes on the back of my front load washer and it seperates the hot water from the cold water and its cracked
Are you referring to the water valve assembly? If so, you can purchase a new assembly. Check with a parts distributor. You will need the brand and model number.
Unplug the washer. Turn off the water supply (hot and cold) to the washer and disconnect the hoses at the washer (there is no need to disconnect the hoses at the wall). Make certain that you replace the hoses correctly on the new water valve with corresponding hot and cold hoses coming from the wall. Disconnect the wire harnesses to each temperature (hot and cold) on the water valve. The harnesses should be color-coded. Replace them correctly on the new valve. Turn the water supply back on and plug in the washer. Run a small water level while testing different temperatures (hot, cold and warm). Check for water leaks and proper temperature.
Feb 20, 2010 | Kenmore Washing Machines
Open Questions:
How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
Jul 16, 2014 | LG WM3431 Front Load Washer / Dryer
Additional details: Questions with more than 25 words are more likely to be answered well. 0 chars Your Question Preview No product selected LG WM3431 Front Load Washer / Dryer How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
See all LG WM3431 Front Load Washer / Dryer Questions
LG WM3431 Front Load Washer / Dryer Logo
247 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
