I can't get my computer's dvd burner to recognize dvds when trying to record..This creates problems when trying to record. There is no problem playing dvds
    Novelist:
  • 119 Answers
Possiboe solutions:
1. download the latest driver for of your dvd player
2. try to use another dvd burner program
3. try this:
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Posted on Jun 20, 2008
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
DVD Burner does not recognize blank dvds
Usually 2 things cause this issue.
Incompatable Media or a Bad Drive.
Make sure the type of disk you have is compatable with your burner. Often off brand or no brand media just won't work. HP burners are picky.
Mar 24, 2009 | HP Computers & Internet
Do I need a special burner to record on DL DVDs?
yes you do, you need a Dual layer DVD burner, not every DVD burner does burn DL DVDs.
please rate if you can
Feb 13, 2009 | Dell Dimension 8300 PC Desktop
I cannot burn DVD's
you need to download Nero for burning DVDs..
Jan 04, 2009 | Acer Aspire (AST180-US340B) PC Desktop
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
Dvd-rw drive not working
Hi Elaine, Usually DVD recording issue can be related to the configuration or Hardware itself. please check if standard CD/DVD recording option is active you can see it by right click on CD/DVD drive and properties. Please check the box highlighted below
If it doesn't work you can contact to DELL hotline or alternately you can post the outcome on here
Good Luck
Feb 07, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Computers & Internet Logo
73 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
