Question about Philips 42PF9630A 42 in. Plasma Television
Did you get to fix it?
I saw your post at FixYa :
"The TV is dead. can not turn it on. Red light blinking four times.
ANy ideas?
Thanks a lot"
I'm wondering if you got to get your tv fixed and how much was the damage, mine died just today :( and have no warranty so I'm going to have to face this but want to have some idea of how bad it is. I have exactly the same issue.
Please, any info can help me.
Carlos.
  • 138 Answers
It depend on the part that your set need. The board are diffrent prices and it depend on who fixes the set.
Posted on Aug 19, 2008
Tv flashing red light
How many times do the standby light flashes, at one time switch ON? These blinks are called blinking codes. From these blinks, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine and half Lakh viewers cannot be wrong.
May 12, 2013 | Goodmans Televison & Video
Hello, I have a 42"
Sounds like a backlight is out. If its still under warranty, exchange it. First try unplugging it for two minutes to reset the t.v.
May 15, 2011 | LG 42LG30 42 in. LCD HDTV
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
When the tv is turned on with the remote control,the red sensor light turns into green and blinks 10 times and the tv comes on, but it goes off immediately.As it turns off ,the sensor light turns into red...
Hi, my name is John. Welcome to FixYa. You have a problem in the D board. I will post what you need to check here, such as the transistors, capacitors etc. thanks for choosing FixYa....John
Nov 30, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Wrong model showed up on my question - need new reply about part
ORDERED SONY PROJECTION REPLACEMENT LAMP - SHOULD ARRIVE IN ONE MORE DAY - KEEPING FINGERS XXX'D THAT THIS WILL RESOLVE THE PROBLEM - BUT THE TECH WAS EXCELLENT RESOURCE! I'M CONFIDENT IT WILL FIX THE PROBLEM AND THRILLED WE CAN DO IT OURSELVES AND SAVE $200! THANKS !
May 18, 2009 | Sony KV-36FV26 TV
Its happening to me...
Four blinking lights means one of your fans are dead. You need to find which one isnt working and replace it. It cost me $19 to order the fan and is an easy fix.
You have to take off the back cover and turn the tv on and see which one doesnt spin and replace it.
Jul 01, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Red light blinking does not turn on
you msy have problem with power supply there are some small caps that give you this problem call a good local TV shop that work in plasma Television (job for experienced Tech)
Apr 07, 2008 | Philips 42PF9630A 42 in. Plasma Television
Is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
Sep 28, 2007 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Philips 42PF9630A 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
