Question about Sony Handycam DCR-TRV350 Digital Camcorder
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
THERE IS A C:31:23 CODE FLASHING ON THE SCREEN AND WHAT LOOKS LIKE A EJECT SIGN FLASHING ON SCREEN I have the same problem with my 350. It renders the unit unusable. I used to be able to overcome it temporarily by disengaging the battery and then re-engaging it. Sometimes it took multiple attempts before it worked. Now, it has become a permanent condition. It comes on as soon as I try to record or playback. I had an earlier high end Sony Digital 8 with the same problem, but this one had gotten wet, so i assumed that was the reason. Now I will have to buy another camcorder unless this can be corrected.
Any inexpensive fixes for this problem?
  • 487 Answers
It is not a fatal error. But the 31 shows the unit has had a short internally and the 23 means only service center of sony can repair this as this is an internal circuitry problem due to the moisture which you have had.
Follow This LINK for Service form Sony they will help you further and they will quote you
Posted on Jun 20, 2008
  • eric bosman
    eric bosman Jun 20, 2008
    Follow this LINK for your service manual
    You will find what I mean
  • 4,234 Answers
The error code indicates that the head/drum assembly is not working correctly. This could be a simple fix, but without seeing the camcorder itself, I can not say for sure. This is not a repair that should be attempted by anyone without experience with cameras. In many cases, no parts are required. Check around for a Sony authorized service center. I would recommend that you get a detailed repair estimate (cost $50 or so) to determine whether or not parts are required and make your decision at that point. Feel free to post the results of the estimate here and we can provide non-biased advice.
Dan
  • ABRsvcs Jun 23, 2008
    Sorry dutchman05, but the error code listed indicates a head/drum motor problem not an internal short. Please stick with the areas you have listed as expertise. I am a Sony service center and can state he problem. This is not a user servicable problem as I initially stated.
    Dan
  • 1,879 Answers
Greetings,
FATAL ERROR CODE : unit is unable to perform requested operation
No reset or fix for that problem.
New camcorder or repair - get a quote for repair and compare price for a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCRE - 673d736.png
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Try first removing the battery and see if this clears the error.
Aug 24, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
What does the engine sign start flashing on a 1994 honda accord exclusive means?
must have someone code read vehiclescomputer to find out.. some things more urgent as compared to others....
Mar 19, 2011 | 1996 Honda Accord
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Help please urgent
It may have been the outer casing to the lamp and the lamp may still be bad - that's normally what the flashing power button indicates. Do you have a specific model number for the tv?
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser and put it back to the socket....
Jun 16, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Message icons
flashing envelope means your msg in SIM ARCHIVE is full.
wap sign means you postpone the dowloading of wap session sent toyou.
Feb 13, 2008 | Sony Ericsson T610
Sony handycam CCD-TRV43 troubleshooting
Some part in the cam is broken and i want to repair it. where should i go in Navi mumbai India?
Aug 08, 2006 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
124 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
