Question about Refrigerators
Defrost timer Thanks for reply to my earlier question. It looks my refrigerator has defrost problem. I tried to locate all the parts for defrost system, but couldn't find defrost timer. Where is defrost timer located for this Frigidaire, model: FRS24XGCW2. I wonder if it has defrost timer.
  • 4 more comments
  • Anonymous Mar 12, 2014
    Where is the defrost timer located on maytag side by side refrigerator model MZD2752GRW
  • Anonymous Mar 13, 2014
    location of defrost timer on viking refregerator
  • Anonymous Mar 23, 2014
    cannot find defrost timer
  • Anonymous Mar 24, 2014
    Refrigerator is not cold
  • Anonymous Mar 26, 2014
    location of the defrost timer
  • Anonymous Mar 31, 2014
    not defrosting how to replace defros timer
    Problem Solver:
  • 3 Answers
Where and what is a url
Posted on Oct 08, 2011
  • 828 Answers
Http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Side-by-side, defrost does not work, fridge has high temperature
Thanks for providing your model number! If other people would do the same they could get help to solve their refrigerator or other appliance problem. Try turning the timer dial clockwise slowly with a flat head screw driver. The location of the timer in your model refrigerator is located inside the control panel inside the fresh food section. Click HERE to see part location number 6 That is the defrost timer=> 482493 Defrost Timer Sometimes there is a round hole on the outside of the control panel where you can place the screw driver and sometimes that hose is covered by a plastic plug. Anyway try turning the timer slow clockwise until fans and compressor stop. Leave the refrigerator off for up to 35 minutes and if it does not restart on it's own then simply turn the timer again slowly until it does restart. If the refrigerator defrost while you have forced defrost this way and timer will not restart refrigerator again on it's own then replacing the timer will be the correct part to replace. If turning the timer does not help in getting defrost we will need to remove items in the freezer to a safe location so you can see what is happening behind the rear wall of the freezer. Item location 33 in the photo HERE is the 2323197 Defrost Heater Assembly Testing the defrost heater can be explained in the video above. Part location number 35 is the=> 2321799 Defrost Thermostat You can test this part but I always change if I need to remover the rear panel of the freezer. I just think it is a good idea. I am here should you have questions, Thanks Sea Breeze
Jul 11, 2013 | Kenmore Refrigerators
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Refrigerator freezing even when you turn it down
Your refrigerator is freezing due to the unit most likely haveing a defrost issue. This is usually caused by the defrost thermostat, the defrost heater, or the defrost timer or adaptive control having a fault condition. If you remove the rear panel in the rear of the freezer it will give you access to the evaporator coil. Located to one of the side usually clipped onto one of the copper lines you will see a small circular round sensor with two wires coming from it. Unplug the machine and defrost with a hair dryer any ice build up on the evaporator coil. If you have a multimeter you can perform a ohms test to assure that the thermostat is working properly. A defrost thermostat usually has an ohms reading of at least .50 ohms or higher. Located under the evaporator coil is the defrost heater. If you unplug both sides of the heater you can also perform a ohms test with a multimeter which would usually read around 21 ohms or higher. Most often this issue is caused due to the defrost thermostat due to this part being manufactured poorly on most all machines. If you find that you have a positive ohms reading on both these mentioned parts. You would then look at the defrost timer or adaptive control as the part causing the fault condition. I will await your reply and to you testing these first two parts before further posting how to test the defrost timer.
I await your reply,
Thank you,
Rick
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Defrost is stuck in one all time it not cooling or freezing
A DEFROST TIMER is a cycling device, it times the frequency and duration that the defrost heater coils melt the ice that builds up around the evaporator coils. If ice is allowed to build up, air will not be able to freely flow past them - resulting in reduced efficiency and sometimes a drastic warming of the cooling unit.
Most of the time, the defrost timer is in the cooling mode, allowing the compressor to activate when the thermostat signals it to. The remaining part of the cycle (usually less than 30 minutes)the timer is in defrost mode. In this mode, it signals the defrost heaters to melt the ice build up on the coils. This defrost action is limited by the defrost thermostat. If your DETROST TIMER go to bad, one symptom would be if your refrigerator is not cooling. Although there are many causes of this symptom, A stuck defrost timer can be one of them. The timer can get stuck in cooling (compressor activated) or defrost mode (defrost heaters activated) for usually two reasons:
- The timer motor can fail for one.
- The gears can also become locked up.
No matter what the reason is or which mode the defrost timer gets stuck in, the refrigerator can stop cooling. When the refrigerator is stuck in defrost mode, the compressor no longer comes on to cool the unit. If the timer gets stuck in cooling mode, the evaporator coils never get a chance to defrost, causing ice build-up to the point where there is a complete blockage of airflow past the coils.
The defrost timer can also cause the refrigerator to stop cooling due to failure of the internal switch which activates either the compressor or heater coils. Finally, when doing any repair on a refrigerator, check the condenser coils for dust buildup and clean accordingly.
According woth yur brand and model, look the part replacement in this link: partselect.com/refrigerator+test-defrost-timer+repair.
Good luck.
Jul 16, 2011 | Refrigerators
The freezer stopped freezing... the temp now reads 40deg (and climbing) and the fridge reads 45deg. I'm mopping up puddles on the floor.
It is possible the refrigerator has gone into defrost and stuck there. I'm not sure what features to tell you to look for but you probably have a defrost timer or something called Adaptive Defrost Control board. They are the part that most likely causes the problem. If you could send me the model number found on the door frame on most refrigerators I would help you locate the parts.. Anyway when they stop cooling like that it reminds me of a defrost timer caught in the defrost cycle and the only way to locate it and turn it clockwise may get you going until the defrost timer can be replaced. I have seen thermostats do the same thing. Thanks Sea Breeze
Aug 17, 2009 | Frigidaire Freezers
Maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Dec 24, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
3,360 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
