Question about Whirlpool Microwave Ovens
I have a whirlpool MH3184XPB undercounter microwave. It has started to hum and the vent fan motor is rotating very slowly like a relay is stuck even when the fan is turned off. Do you know what the problem is?
  • Whirlpool Master
  • 9,086 Answers
It's probably a shorted relay or triac on the control panel.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 23, 2008
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
Model mh3184xpso whirlpool microwave the vent fan for steam from the stove is humming in the off position. it works on all speeds but it runs real slow on the off position and hums.
Have you recently had a failure with the cooktop lights?
If so, we see (and repair) this a lot. The problem is on the control circuit board, which we regularly repair nationwide by mail for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Even if you've not had a recent failure with the lights, i would bet it's a leaky hood fan triac on the control circuit board.
Mar 13, 2011 | Whirlpool MH3184XP Microwave Oven
No power on unit. power ok at outlet. it's a 2005 whirlpool mh3184xpb-1
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Whirlpool Microwave Ovens
My microwave is making a humming noise when plugged in and the fan continues to run when not in use what is wrong?
is the turntable rotating?
I suspect a jammed motor drive and a short circuit in this situation. I would be seeking a quote for repair and not trying to use it incase it over heats and catches fire. The continuos running of the fan is a definite worry Unplug it before touching it in case some parts of the case are live.
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Whirlpool MH7140XF Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Frigidaire PLMV169CD Micowave Hood Vent fan Hums, but won't run
If you have an old analog multimeter, you can put it across the motor start capacitor and the needle should deflect to low ohms position then ramp up to the open or infinite ohms position. You can remove it and test it the same way. Also, doing this test should store a dc voltage on the leads which can then be read even with a digital multimeter. I have even used an audio output from a cheap amplifier to determine if audio is transmitted from one lead to another. The capacitor works by shifting the starting current by 90 degrees and the motor acts as you say it does if the cap is bad. Make sure you orient the cap properly with the positive and negative terminals in the proper holes
Nov 30, 2007 | Whirlpool MH1150XMQ Microwave Oven
Exhaust fan
It sounds like the bearings may be going bad on the fan motor. It's also possible that there may be sonething stuck in the the grlle or fan area, like a paper label, etc. You can find exploded views and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly help files at our site, which you can find via our listing here: http://tinyurl.com/yzjozk
Jan 23, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
335 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
