Question about RCA Lyra RD2763 MP3 Player
Hard disk temperature too low!
Thus us the message I get and the device won't do anything else. I had some of the other problems listed, file system corrupt and downloaded a patch to fix it. Then started to have the profiling issue and now this.
Same problem for me. First it started showing "file system corrupt", then the screen wouldn't stop flashing, then I got the "hard disk temperature too low." I found that the temporary solution is to unscrew the back, take the battery and 5 GB micro drive out of their slots without disconnecting the terminals, and placing them back in their spot. Not sure of the reasons behind these problems, but it could be because the manufactures cheaped out on the processor design to save money. If the screen does a flashing blue toggle repeatedly, I found the best thing is to take the back off, find the LCD output pins and run a screwdriver across them until the screen goes blank. This seems to do a good job of resetting the display. Mine works fine for now, we will see how long it lasts.
Posted on Oct 13, 2008
I had the same problem on my daughter's Lyra 5GB MP3 player. I fully charged it, tried the 10 second power button reset, and was on the way to remove the back to check the disk drive cable when my daughter dropped it and it started working again!
Good job too, since when I checked, the disk drive connector appeared to be soldered on.
Posted on Jul 03, 2008
I always get a message that I have low disk space on my C Drive.I always do a cleanup but never have enough.Can I just take my hard drive to my local computer shop and buy more disk space?
Hey run Disk clean up command
Windows includes a built-in tool that deletes temporary files and other unimportant data. To access it, right-click one of your hard drives in the Computer window and select Properties.
Click the Disk Cleanup button in the disk properties window.
4-fyhrps5fgfplomibuptu3dbk-4-14.png Select the types of files you want to delete and click OK. This includes temporary files, log files, files in your recycle bin, and other unimportant files.
You can also clean up system files, which don't appear in the list here. Click the Clean up system files button if you also want to delete system files.
After you do, you can click the More Options button and use the Clean up button under System Restore and Shadow Copies to delete system restore data. This button deletes all but the most recent restore point, so ensure your computer is working properly before using it - you won't be able to use older system restore points.
Jul 22, 2017 | Hard Computers & Internet
USB flash
What format is the drive
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Nov 26, 2012 | Kingston Digital DataTraveler 4000 8 GB...
Low disk space
This couldn't be due to a malfunctioning fan, or any other hardware problem, it certainly sounds like a virus but it's hard to know. I advise using this guide t try and remove any viruses or malware.
Oct 21, 2012 | Compaq CQ2103WM-B (884962083048) 17 in. PC...
I'm getting an error message of 0xb900009f
Lots of issues can be responsible for your error message:-
Access deniedThis error occurs if the user has insufficient privileges to a file, or if it has been locked by some program or user.The device is not readyThis error most often occurs when there is no floppy disk (or a bad disk) in the disk drive and the system tries to perform tasks involving this disk.File not foundThe file concerned may have been damaged, moved, deleted, or a bug may have caused the error. Alternatively, the file simply might not exist, or the user has mistyped its name.Low Disk SpaceThis error occurs when the hard drive is (nearly) full. To fix this, the user should close some programs (to free swap file usage) and delete some files (normally temporary files, or other files after they have been backed up), or get a bigger hard drive.Out of memoryThis error occurs when the system has run out of memory or tries to load a file too large to store in RAM. The fix is to close some programs, or install more memory.[program name] has encountered a problem and needs to close.
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
How to Free up low disc space on asus 901?
  1. Open Disk Cleanup by clicking the Start button. In the search box, type Disk Cleanup, and then, in the list of results, click Disk Cleanup.
  2. In the Drives list, click the hard disk drive that you want to clean up, and then click OK.
  3. In the Disk Cleanup dialog box, on the Disk Cleanup tab, select the check boxes for the file types that you want to delete, and then clickOK.
  4. In the message that appears, click Delete files.
Nov 25, 2011 | ASUS Eee PC 901 XP Notebook
My hard disk iomega, model select from 320 gyga does not work anymore and is out of warranty ... the error message of my pc is that some files may be corrupted or damaged ... Software HDD Regenerator find...
> what can I do?
Open the case, remove the "dying" disk-drive, and purchase a new, compatible, disk-drive, and "transplant" it into the enclosure, thus reviving your external storage device.
Dec 30, 2010 | Iomega Select 320GB USB 2.0 Black Portable...
I HAVE A AOPEN COMPUTER IT IS A MILENIUM ONE IT NEEDS A BOOT DISK HOW COULD I GET ONE
Your computer tries to "boot" (restart itself) from several devices:
* 3.5-inch floppy-disk
* CD/DVD drive
* disk-drive
* USB memory-stick
* and others
When it cannot boot from one device, it tries the next.
So, either:
* you have changed the list of boot-devices to EXCLUDE the disk-drive;
* the list of boot-devices INCLUDES the disk-drive, but the attempt to "boot" from the disk-drive has failed.
Thus, the "insert boot disk" message says that all of the eligible devices were tried, and the "boot" from each of them has failed.
So, check that your disk-drive is INCLUDED in the list of boot-devices.
If it is, then your _REAL_ problem is that your disk-drive is either "logically" damaged, meaning that the "boot-records" on the disk have been overwritten, or "physically" damaged, meaning that *NO* information can be read from your disk-drive.
Take your computer to a qualified technician, to check the "health" of your disk-drive.
Sep 24, 2010 | Computers & Internet
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
RCA Lyra RD2763 MP3 Player Logo
487 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
