I have an 80G Nexxstar exrernal hard drive , but my conputer does not re cognize it. I have a driver that will not install bwecauseit tells be to "insert disc 1 but tee is only 1 disc. I have windows xP
  • 197 Answers
Is the hard drive pluged in to a usb port or how is it pluged in
Posted on Jun 20, 2008
My C drive says 19.5g but i have an 80g hard drive
Create another partition on it and use it to store all your files (instead in MyDocuments) it's safer that way if your OS gets destroyed by viruses.
Apr 09, 2010 | Computers & Internet
Can't reconize maxtor basic
Here is the support website for the Maxtor....>
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
You will find drivers and things here....
Jul 01, 2009 | Maxtor BASICS Personal Storage 3200...
Problems with cavalry 500gb external memory
The driver for this specific device is missing or corrupt. simply re install the driver information and, this will fix it.
Feb 17, 2009 | ACP Cavalry (CAUE37500) 500 GB USB 2.0...
Maxtor 80G won't work with ACER Inspire One notebook useing linus
Here is the support section for Maxtor:
http://www.seagate.com/www/en-us/support/downloads/
Seagate acquired Maxtor a few years ago and is handling all support on Maxtor products.
Dec 27, 2008 | Maxtor Hard Drive
Problem in cd-dvd drive of hp laptop
This is not a driver problem. It is almost certainly a problem with yourdvd/cd player. If it is reading dvd's, then it means that the driver is installed. You will have to take your laptop in and possibly get the cd/dvd player replaced.
Dec 09, 2008 | HP RT865UTABA - HP Promo dc5700 micro...
Cant get the maxtor 80g hard drive to connect with my pc
TAKE IT OUT AND RE-INSTALL IT.CHECK THE JUMPERS AND MAKE SHURE THEY ARE SET TO MASTER OR FACTORY SETTINGS.LOOK AT THE JUMPERS ON THE OLD HARD DRIVE THAT YOU ARE REPLACING AND SET THEM EXACTLY AS THAT DRIVE.CHECK ALL CONNECTORS AND RIBBONS FOR SOLID CONNECTIONS.SOMETIMES,THE PINS INSIDE THE HARDDRIVE CONNECTOR BEND SLIGHTLY.IT IS REALLY HARD TO TELL UNLESS YOU REALLY LOOK AT THEM CAREFULLY.
Aug 22, 2008 | Computers & Internet
I have a st380011a 80g hard drive
you need diskmgmt.msc if its a slave drive unalocated.. create partition then format it OR .. if its to install windows on it. boot from xp cd . sometimes sata drives need F6 floppy motherboard driver for installation cd to see sata hd through chip of sata on motherboard.
Jul 14, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
*Note*
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | HP Compaq d530S PC Desktop
Slave Drive not recog in my computer but it is disk management with no drive letter
A quick thing to try Is
remove the 80gb from ide cable and power plug and set the 20gb back as master.
boot into windows from 20gb 1 time ,
then shut down hook the 20gb as a slave and the 80 back up as master
Allow windows to find new hardware , "watch closely down by clock ". It will tell you when windows has finished and will say you might need to reboot before new hardware will work properly
After rebooting Both should show inside My computer
Good Luck I hope this helps
Nov 14, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Computers & Internet Logo
David Payne
David Payne
