Question about Philips 43PP9202 43" Rear Projection Television
My phillips model 60pp920217f
Ok the color seems fine but a the bottom of the screen if there are words (more noticeable) they seem to be written right above it in green..like a double image..this is only at the bottom. I restored factory covergence and it still appears . When I ran the service convergence and did a test it says that 1,2,3,4 not lined up. Any ideas? I am uable to allign the red convergence on my Phillips 60PP920217F. I read through the other posts with the same problem and ordered the parts suggested. The parts arrived and I disassembled the set to find that part number STK392-110 is not what is inside. My set has STK392-120. The parts were $40 for 2 and I do not expect the shipper will give a refund. Do you know if these parts will work or if STK392-1120 will be different enough to matter? Thanks!
  • 4,234 Answers
The two parts have the same pin-out but the 120 can handle more power. If you install the 110 version, expect it to fail rather soon. If you call the distributer from whom you recewived the parts, they will likely exchange them for the correct ones for the difference in cost plus shipping. It won't hurt to ask. Check in the area of the ICs for open pico fuses or open low valuied resistors. Either can cause the problem that you are seeing.
Keep us posted.
Dan
Posted on Jun 20, 2008
When you turn tv on it just makes a clicking sound its a phillips model 60pp920217f
If the front panel indicator lights, you are getting power to your TV. The symptom you describe suggests the power supply has failed
Jan 04, 2013 | Philips TV Tuner Video Capture PCI Card -...
Dell Latitude D620 Nvidia Quadro NVS 100m
Suspected it's a graphic error. Try re-installing your video driver to it's later version.
May 30, 2009 | Dell Latitude D620 Notebook
Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F big screen TV
does anyone know why the picture does not come on .Is there any fuses that might of gone bad?If you know respond to this ?thanks
May 15, 2008 | Televison & Video
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
You may have to do the full convergence alignment for all three CRTs, as outlined in the service manual for your model. Do you have the full service manual for your set which outlines the alignment and convergence proceedures?
May 08, 2008 | Philips 43PP9202 43" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Philips 43PP9202 43" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
