Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice maker problems
I have the same problem. Did you figure it out?
  • 294 Answers
The water dispenser is a separate line so it will not have bearing on the icemaker supply side. First up you can take a hair dryer and use it on the fill tube that fills the tray, it may have just frozen shut. If that does not solve the issue, fill the tray by hand and see if it freezes and dumps that ice. Let me know what you find
do rate me
Posted on Jul 07, 2009
Ice maker does not make ice
Hello, Ice makers are very simple machines and only have 2 components. The first is the ice maker located inside the freezer, The second is the dual valve located behind the refridgerator behind the panel at the rear. One valve is for the ice maker, the other is for the water dispenser. When one of these components go bad the result is no ice. There is a very simple way for the layman to figure out where your problem lay. If you have a ping pong ball or shot glass place it on the icemaker and wait 12 hours, if the ping pong ball falls into the ice try the ice maker is good and you need to replace the inlet valve...if the ping pong ball stays in place it means the ice maker is bad and you should replace this. If you have any other questions regarding this problem please feel free to comment again. Good Luck!!! Mike
Sep 02, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice maker won't make ice
The water valve has 2 solenoids one for water and another for ice. The water solenoid is connected to a larger hose than the icemaker solenoid. The water solenoid is working but the Ice maker solenoid might be dead. BUT the ice maker might not be calling for water. It is the ice maker that powers up the solenoid to fill the ice mold. At the end of harvest a tiny copper plate mounted behind the main drive gear rubs across a copper contact. To tweek the amount of water a small screw is mount at the 3 oclock position of the ice maker head.HERE are some repair tips and photos
Aug 05, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
Ice machine quit making ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | GALAXY Microsystems 25.4 cu. ft....
I have an internal icemaker that does not make ice. PN wr30x0328
Mike
Jul 11, 2008 | GE Refrigerators
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
182 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
