Printartist login error box comes up on screen can't con tinue with activating program..
  • 6,487 Answers
Try to run again the Printartist software that is installed on your pc and that should ask you to re-activate it,
If still the same try doing this to unregister adn re-register it again:
Unregister and then re-register the file msiexec.exe by following these steps:
  1. From your desktop click on the Start menu and then select Run
  2. In the Open field type: msiexec /unregister and then click OK.
  3. Re-register the file by clicking on Start and then Run again and type in:
    msiexec /regserver
  4. and then click OK. Install the software.
  5. This is to clean the register for the software and try to reinstall it again and you should be able to activate it.
Posted on Jun 20, 2008
  • 2,071 Answers
Try this option go to menu setting and default the factory setting or factory default this is good for abnormal operation of the program...
  • 1,879 Answers
Greetings,
What is the exact error message ?
Look for other links/shortcut from the Start Menu list (something like Activate)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Got a E004 error up on Casio ar-c2000, pressed c according to manual but just all F's appearing on screen tried everything but coming back to same problem
Press SUBTOTAL and it should return to normal. If you used login codes, you might have to login again. If the program has gone, the batteries were flat and it will need re-programming. Most manuals are here if you need them:
https://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Jan 15, 2016 | Retail Supplies
I am getting error code 0x80070005, how do i fix this
Windows Activation Error : Error Code 0x80070005 I have upgraded my x64 Vista to x64 Windows7. After adding to companies domain, it asked to activate windows again. but its giving the following error when i try to activate it : "Windows Activation Error : Error Code 0x80070005"
The link for the fix is described at the Microsoft Website, link listed below.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-activation-error-error-code-0x80070005/90fb852d-a507-4c76-a672-0be2ecbdb320
Sep 30, 2013 | Toshiba Computers & Internet
Unable to login
You need to reinstall the software.
Oct 07, 2012 | Individual Software Typing Instructor...
How to remove ask for genuine microsoft software
1. Restart your com­puter, hit F8 before win­dows load­ing screen to go into the safe mode menu.2. Select Safe mode (not with net­work­ing, and not with com­mand prompt)
3. Once your in win­dows, goto START>RUN> type "regedit" (with­out the qou­ta­tion marks) and hit ENTER.
4. Goto EDIT, select FIND
5. Search for wgatray.exe, delete any ref­er­ence found, (after it finds it the ini­tial first time, just hit F3 to con­tinue the search. Con­tinue to delete any­thing it stops on.
6. Scroll all the way back up inthe reg­istry edi­tor, and select My Com­puter (one click. not two) and start a new FIND, this time were look­ing for Wga­l­o­gon, again, delete any ref­er­ences found.
7. Lastly, again, click on My com­puter, and start a new FIND, search­ing for LegitCheckControl.dll , again delete any ref­er­ences found.
8. Reboot and your fin­ished, if not, you may have missed a reg­istry entry.
BTW you should be able to con­tinue to down­load Win­dows update (when set to auto­mat­i­cally down­load an install).
Aug 20, 2011 | Microsoft Windows XP Professional for PC
Had to redo computer and reinstall. PA 4. won't install.
I found a solution for installing Sierra Print Artist 4 on XP at this site
http://forum.oldversion.com/programs-support/5831-printartist-4-a.html I did it, works great!
Posting below, thanks to izzy_eckerslike :
"""There is a way to force your computer to load print artist 4
Click on display /settings & reduce colour quality to 16 bit & reduce your screen resolution to 800X600
Then insert the Printartist disk & select install, as before you will see the Sierra logo on your taskbar but it won't move or do anything.
Now put your screen settings back the way they were before & you should see the install screen jump off the taskbar so you can access it.
It will test your computer & tell you it fails as it can't recognise newer technology but ignore that & select 'install anyway' & all should be working"""
Jun 30, 2009 | Sierra Print Artist Platinum
I turned off a WinXP Service - now I cant get the login to start
If you have another computer available you can make a bootable cd that will run a program to reset your admin password. Several of those programs are discussed here. Good luck to you.
Apr 21, 2009 | Microsoft Windows XP Home Edition
If function in excel
Where data is in Column A1, place this in B1
=IF(AND(A1>=810001,A1<=810500),"TINU",IF(AND(A1>=810501,A1<=851000),"MINU",IF(AND(A1>=851001,A1<=852000),"PINU","")))
Jan 09, 2009 | Microsoft Office Standard for PC
Can't connect to my yahoo e mail page
have you tried refreshing your browser? can you login at different times yahoo might be congested.
Oct 20, 2008 | Yahoo Mail
Printartist installation
what does the error clip say
Jun 20, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
