Question about D-Link MediaLounge DSM-120 MP3 Player
Stuck on Loading Screen
So here is the problem...
I have a DSM-120, and I just pulled it out of the box, plugged in the power, and configured it, and then as soon as it is done, it mentions there is a new firmware. So I accept it to install because, well, usually firmware upgrades fix problems so its common sense. Turns out that as soon as it reboots, it is stuck at the loading screen. So I emailed DLink Tech Support, they tell me to reset. So I push the reset button, and its not responding to it, it seems. Loading screen is still there, and has been there for 2 weeks now. Any Help would be great. I probably have to RMA it though :( I strongly dislike Shippings costs! ha ha!
  • 1 more comment
  • mrsir115 Jun 20, 2008
    curses...spam
  • Anonymous Jan 01, 2009
    Mine did not load either. Unplugged it and now I just have a brick.
  • Rod Amo
    Rod Amo Apr 07, 2017
    Send it back immediately
    Habit-Forming:
  • 64 Answers
Return it immediately
Posted on Apr 07, 2017
5 Suggested Answers
  • 59 Answers
SOURCE: Problem Accessing Shared Folders in Network Stoarage Device
vista is only going to complicat things, try re mapping the drive, delete the shortcut and use my network places to find the drive then make a new shortcut to it if you can access it from there, i've had windows 2000 do the same thing especially with my laptop that I take to school, it a lot of times its due to changing ip's but occasionally windows just seems to forget where stuff is on the network and needs to be reminded. shortcuts can be made by draggin the folder to the desktop or desired location or right click the share you want mapped and select map network drive.
Posted on Apr 21, 2007
  • 6 Answers
SOURCE: having problem installing my dlink dir615 router
First, is the problem truly that you can't get an IP address from the router or is it that you can't get on the internet. I will touch base with both issues briefly. Many newly placed routers need the MAC address cloned within the router setup to register with the ISP and recieve internet access. If the PC is truely not recieving an IP from the router, make sure DHCP is turned on and set a range of address you wish use. Tip: limit the number of addresses to only what you will actually use. Make sure your computer is set to recieve an IP automatically and you have the proper client, service and protocols running. Basically, If the PC will run directly from the cable modem, then it should run from the router also. If the PC will not obtain an address from the modem directly then your winsocket may be corrupt. Malware will often do this. It is easily repaired and there are many winsock32 repair tools on the net. Just Google "winsock repair" without the quotes and you will find a multitude of software.
Posted on Jan 21, 2009
frcs68
  • 1605 Answers
SOURCE: Does not accept ( -)
the following characters are not permitted as part o fpassword for any devices. they have special meaning in DOS scripts.
` ~ ! @ # $ % ^ & * ( ) - _ = + \ | [ ] { } ;' " , . < > ?
so change your password.
Posted on Apr 01, 2009
  • 137 Answers
SOURCE: D-Link DWL-810+ is stuck at firmware upgrade screen
Push in the reset button for a good 10-12 seconds on the router.Then start the whole process again.
Posted on Jul 10, 2009
I have a 2006 lincoln ls sport and the drivers seat is stuck in one position there is only power to the lumbar
The dirver seat module is attached to the underside of the seat frame. It must be calibrated if replaced. The dealer can use a tool to get failure codes (DTCs) from teh module. 1/2 hour labor charge to extract codes.
Front Seats
The front seats have the following features:
  • Driver memory
  • Power lumbar (optional)
  • Manual lumbar
  • Horizontal, vertical front and rear tilt adjustments (driver)
  • Horizontal, vertical front tilt adjustment (passenger)
  • Power recline
  • Climate controlled (optional)
Adjustment of the seat may be accomplished with the seat control switch located on the side of the seat.
Principles of Operation
Driver Power Seat - Memory
NOTE: The memory power seat track may stall when operating at 0°C (32°F) or below. Once the vehicle's interior temperature rises above 0°C (32°F), normal operation should return.
The driver power seat is controlled by the driver seat module (DSM). The DSM does not need to be configured, however the driver seat does need to be calibrated when the DSM is installed. The driver seat control switch provides voltage to the DSM when activated. The NEUTRAL position of each driver seat control switch position is a ground state through the seat control switch contacts. A voltage input causes the DSM to power the appropriate motor until the input is removed. Ground is the normal state of the motor circuits through the DSM and is not switched to control the motors. The DSM internally switches the appropriate line from ground to power to adjust the motors.
As the seat is adjusted, the DSM constantly monitors the motor position sensors to record the current seat position. The DSM will remove power from the motor upon termination of the seat control switch input or if the DSM does not see movement from the motor by monitoring the position sensor. The DSM must be calibrated to the seat track it is controlling. For additional information, refer to Seat Calibration. Once the DSM is calibrated to the seat track, it will only allow movement within the calibrated range.
Seat Calibration
The DSM is calibrated using a diagnostic tool. The calibration procedure automatically powers the driver power seat through its full range of motion and records the FULL STOP positions by monitoring the motor position sensors. Once the FULL STOP positions or range of the seat have been recorded, the DSM will only operate within the calibrated range. Any input attempting to drive the seat beyond the calibrated range will be ignored. This calibration is used for all seat control functions including manual switch control and memory recall positioning. During the seat calibration, the DSM may identify a function that is inoperative, such as a position sensor not changing. If the DSM identifies a concern that has a related diagnostic trouble code (DTC), the DSM will set the related DTC at the end of the validation procedure.
The calibration procedure powers the seat track adjustments to the end of their travel, which is determined by the DSM sensing a change of state in the motor position sensors. If there is a concern with the seat track or motor position sensor that limits the travel, the DSM will interpret the stopping point as the end of travel and store the position. The DSM is not able to determine if the seat has moved to its FULL TRAVEL position. It is only capable of monitoring and storing the amount of travel seen by the position sensor changing states.
For additional information on carrying out the power seat calibration procedure, refer to the diagnostic tool operating manual.
Memory Seat
Memory seat positioning can be recalled with the memory switches on the driver door panel or a programmed remote keyless entry transmitter. In either case, the DSM receives a memory recall 1 or 2 command from the driver door module (DDM) over the SCP communication network. The memory recall switches are a hardwired input to the DDM. The DDM also receives the remote keyless entry transmitter signals. Once a valid memory recall command is received from the DDM, the DSM moves the driver seat to the position stored in memory by powering the appropriate motors and monitoring the motor position sensors until the position is reached.
This system allows automatic positioning of the driver seat to 2 programmable positions.
  • To program position 1, move the driver seat to the desired position using the seat control switch. Depress the set button. Within 5 seconds, depress button 1.
  • To program position 2, repeat the previous procedure using the set button and button 2.
  • To recall position 1, depress button 1. To recall position 2, depress button 2.
A position can only be recalled when the transmission selector is in PARK or NEUTRAL. A position may be programmed at any time.
Easy Exit/Easy Entry
The easy exit function moves the seat backwards about 2 inches when the ignition key is removed from the ignition switch. The DSM receives a key out command over the SCP communication network and powers the driver seat rearward. This function will not operate if the seat is less than the travel distance to the end of the track, or the function has been deactivated at the message center driver personality settings. The DSM will also cancel this operation if a valid input command is received, such as the seat control switch or memory recall request.
The DSM will record the current seat position before powering the seat for an easy exit function. This recorded position will be used to return the seat to this position on the easy entry operation. During easy entry operation, the seat is returned to the position previous to the easy exit operation. Easy entry operation will be cancelled if a valid input command is received by the DSM.
Passenger Power Seat
The passenger power seat motors are hardwired to the passenger seat control switch. The circuits are normally at ground through the seat control switch. The individual circuit is switched to power when the specific adjustment position is selected.
Visual Inspection Chart Mechanical Electrical
  • Front seat track motors
  • Front seat track binding or obstructed
  • Front seat backrest power recline
  • Lumbar motor
  • Climate controlled seat ducts
  • Driver door module fuse(s):
    • Central junction box (CJB) fuse 7 (5A)
    • CJB fuse 22 (10A)
  • Driver seat module fuse(s):
    • Battery junction box (BJB) fuse 21 (20A)
    • CJB fuse 7 (5A)
  • Passenger power seat BJB fuse 28 (20A)
  • Rear heated seat fuse(s):
    • BJB 11 (20A)
    • CJB fuse 16 (5A)
  • Driver power lumbar BJB fuse 21 (20A)
  • Passenger power lumbar BJB fuse 28 (20A)
  • Driver and passenger climate controlled seat module fuse(s):
    • BJB fuse 26 (30A)
    • CJB fuse 16 (5A)
  • Seat control switch
  • Memory set switch
  • Lumbar seat control switch
  • Seat fan motor
  • Climate controlled seat module
  • Climate controlled seat switch
Jan 14, 2011 | 2001 Lincoln LS
Raymarine "DSM connection lost"
Murray,
Has the DSM and the E120 software been upgraded to the latest software: 4.12 for the DSM and 5.52 for the E120?
Try this first. You can download the software off Raymarine.com and burn each to a separate compact flash card.
I have seen many problems like you are experiencing solved with this simple change.
If this doesn't solve the problem, the DSM will have to go back to Raymarine for repair.
Apr 19, 2010 | Raymarine Dsm30 Digital Sounder Module
Power mirrors, driver power seat, adjustable pedals all don't work... checked fuses and all ok... Any suggestions?
it sounds like the driver seat module. It controls all of these items.
buy used at car-part.com. look on page with * for lowest price.
buy new at discount at tascafordparts.com
  • The memory mirror is inoperative
  • Driver seat module (DSM).
  • Circuitry.
  • CJB fuse 3 (7.5A).
  • Exterior mirror motor.
  • Mirror control switch.
  • The memory seat is inoperative
  • Circuitry.
  • Seat control switch.
  • Seat track.
  • DSM.
  • PDJB Fuse 109 (30A).
  • Power seat motor.
  • Adjustable brake pedal does not operate correctly — does not operate using the adjustable pedal switch
  • Battery junction box (BJB) fuses:
    • 109 (30A).
  • Circuitry.
  • Switch.
  • Adjustable pedal motor.
  • Driver Seat Module (DSM
Oct 02, 2009 | 2003 Ford Expedition
2001 Lincoln LS Easy Entry power seat function
may need dealer to reclaibrate using his tool.
Driver Power Seat The driver power seat is controlled by the driver seat module (DSM). The DSM does not need to be configured, however the drive seat does need to be calibrated when the DSM is installed. The driver seat regulator control switch provides voltage to the DSM when activated. The neutral position of each driver seat regulator control switch position is a ground state through the seat regulator control switch contacts. A voltage input causes the DSM to power the appropriate motor until the input is removed. Ground is the normal state of the motor circuits through the DSM and is not switched to control the motors. The DSM internally switches the appropriate line from ground to power to adjust the motors.
As the seat is adjusted, the DSM constantly monitors the motor position sensors to record the current seat position. The DSM will remove power from the motor upon termination of the seat regulator control switch input or if the DSM does not see movement from the motor by monitoring the position sensor. The DSM must be calibrated to the seat track it is controlling. For additional information, refer to Seat Calibration. Once the DSM is calibrated to the seat track, it will only allow movement within the calibrated range.
Seat Calibration The DSM is calibrated using a scan tool. The calibration procedure automatically powers the driver power seat through its full range of motion and records the full stop positions by monitoring the motor position sensors. Once the full stop positions or range of the seat have been recorded, the DSM will only operate within the calibrated range. Any input attempting to drive the seat beyond the calibrated range will be ignored. This calibration is used for all seat control functions including manual switch control and memory recall positioning. During the seat calibration, the DSM may identify a function that is inoperative, such as a position sensor not changing. If the DSM identifies a concern that has a related diagnostic trouble code (DTC), the DSM will set the related DTC at the end of the validation procedure.
The calibration procedure powers the seat track adjustments to the end of their travel, which is determined by the DSM seeing a change of state in the motor position sensors. If there is a concern with the seat track or motor position sensor that limits the travel, the DSM will interpret the stopping point as the end of travel and store the position. The DSM is not able to determine if the seat has moved to its full travel position. It is only capable of monitoring and storing the amount of travel seen by the position sensor changing states.
For additional information on carrying out the power seat calibration procedure, refer to the scan tool operating manual.
Memory Seat Memory seat positioning can be recalled with the memory switches on the driver door panel or a programmed remote keyless entry transmitter. In either case, the DSM receives a memory recall 1 or 2 command from the driver door module (DDM) over the SCP communication network. The memory recall switches are a hardwired input to the DDM. The DDM also receives the remote keyless entry transmitter signals. Once a valid memory recall command is received from the DDM, the DSM moves the drivers seat to the position stored in memory by powering the appropriate motors and monitoring the motor position sensors until the position is reached.
Easy Exit/Easy Entry The easy exit function moves the seat backwards about two inches when the ignition key is removed from the ignition switch. The DSM receives a key out command over the SCP communication network and powers the driver seat rearward. This function will not operate if the seat is less than the travel distance to the end of the track, or the function has been deactivated at the message center driver personality settings. The DSM will also cancel this operation if a valid input command is received, such as the seat regulator control switch or memory recall request.
The DSM will record the current seat position before powering the seat for a easy exit function. This recorded position will be used to return the seat to this position on the easy entry operation. During easy entry operation, the seat is returned to the position previous to the easy exit operation. Easy entry operation will be cancelled if a valid input command is received by the DSM.
Passenger Power Seat The passenger power seat motors are hardwired to the passenger seat regulator control switch. The circuits are normally at ground through the seat regulator control switch. The individual circuit is switched to power when the specific adjustment position is selected.
Heated Seats The driver and passenger heated seats share a common battery and ignition feed. A separate shared ignition source supplies the heated seat switches. When the heated seat switch is pressed with the ignition switch in RUN, a momentary voltage signal is sent to the heated seat module. The heated seat module then supplies power to the heating element circuit. The cushion element and seat backrest element are wired in series and powered by the same output. The heated seat module also will ground the separate indicator circuit at the heated seat switch to indicate an ON state. The heated seat module will remain on until the heated seat switch is pressed and a momentary voltage signal is received, or until 10 minutes expire. If the ignition source is removed from the module, the heated seat module will enter an off state and will not return to ON until the switch is once again pressed with the ignition switch in RUN. The heated seat module is designed to heat the seat to 37.5°C (99.5°F) and maintain the temperature until time-out or switched off. This temperature is maintained by the heated seat module monitoring the temperature sensor located in the seat cushion element, and adjusting the current flow to the heating elements.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
    • Front seat track motors.
    • Front seat track binding or obstructed.
    • Front seat backrest power recline.
    • Lumbar motor.
    • BJB Fuses 411 (15A), 421 (20A), 425 (40A), 428 (20A)
    • CJB Fuses 205 (5A), 216 (5A), 207 (5A)
    • Seat regulator control switch.
    • Memory set switch.
    • Lumbar seat control switch.
May 04, 2009 | 2001 Lincoln LS
2001 Lincoln LS. Selecting seat/mirror/steering wheel positions works for all except the driver seat. Could this be a fuse/breaker problem? If so, where are they? Is there other possible cause for this?
you may need to have the dealer calibrate the seat with his diagnostic tool. I would guess ariund 1 hr labor time.
info:
    • Lumbar motor.
My side mirros dont work
The exterior mirrors:
  • are controlled by power controls on the LH front door trim panel.
  • are of a foldaway design.
  • may contain turn signal indicators.
  • may be heated when the heated back window glass is activated.
  • may have a programmable recall memory option.
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
Power Exterior Mirror Operation
The power exterior mirrors are controlled by the DSM and are operational all the time, whether the ignition switch is on or off. Using the power exterior mirror switch, the driver can adjust the driver and passenger exterior mirrors four ways.
  • Exterior mirror(s)
  • Interior mirror
  • Circuitry
  • Exterior mirror control switch
  • Interior mirror
  • Memory set switch
  1. If the vehicle is equipped with memory exterior mirrors and the concern remains after the inspection, connect the diagnostic tool to the data link connector (DLC) located beneath the instrument panel. Select the vehicle to be tested from the diagnostic tool menu.
    • Check to make sure the program card is correctly installed.
    • Check the connections to the vehicle.
    • Check the ignition switch position.
  • The mirrors are inoperative
  • Circuitry.
  • Central junction box (CJB) fuse.
  • Exterior mirror control switch.
Apr 07, 2009 | 2003 Lincoln Navigator
Diamond MP3 Player DSM-908
Sorry this ain't a solution but the loading screen won't go away..so my comp. can't find it .. therefore i CAN'T format it....
so we basically have a similar problem!
Mar 28, 2008 | Nefertech Diamond MP3 Player
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
D-Link MediaLounge DSM-120 MP3 Player Logo
106 people viewed this question
Top D-Link Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a D-Link Audio Player and Recorder Expert? Answer questions, earn points and help others
