Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker bar sticking at bottom now a loud grinding noise
We bought a used frig from our neighbors. The ice machine bar raises and comes back down but seems to get stuck right before it reaches the bottom. There is no ice in the way and if you manually push it down it will dump the ice and continue the cycle only to become stuck again. We noticed this going on for about 2 weeks or so and now occasionally we are hearing a loud grinding noise which lasts for about a half hour then quits on its own. This has happened a couple of times. An ideas or suggestions?
  • Anonymous Jul 05, 2008
    I have a Frigidaire Refrigerator, Model FRS26ZRG side by side. The wire cut off arm is hung in the up or cut-off position and will not come back down and therefor will not make any ice. It seems to be locked or hung in the up position. I am afraid to force it back down. What is the problem there?
  • 725 Answers
You can replace the whole ice make or remove the head and replace the cut off cam inside the ice make head..
hope it helps
Posted on Jul 25, 2008
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Regular loud cracking and popping noises in Maytag bottom freezer. New how to resolve
this is unfortunatley a model problem
its the plastic changing temp
and expanding and contracting
Oct 03, 2009 | Maytag MFD2560HES Bottom Freezer French...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice maker noise when filling
replace the water fill valve it is at the bottom where the water line conect to the unit
Nov 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud grinding noise
the gear may be wearing out.
Jul 31, 2008 | Frigidaire FRS26R4A Side by Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
255 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
