Question about Akai LCT3201AD 32 in. LCD Television
Sharp tv The tv just stopped working. We can't turn it on!
  • 186 Answers
First do a hard reset by unplugging it for a couple hours, then plug it in and try again to power it on. If no change, or power light just flickers then goes off again, your power supply may need rebuilt or replaced. Try this reset first, post back if no change.
Posted on Jun 20, 2008
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Mar 06, 2012 | Sharp LC Televison & Video
I don't have a solution, but the same thing happened to ours. To sidestep the problem, I just left it on 24/7. Eventually (three days ago) it just stopped working completely.
Dec 25, 2010 | Sharp LC-32SH12U TV
Sharp tv ...want to use Rca remote D770 how do I program the remote?
Press and hold the device button you want to program (TV). Then type in one of the codes for Sharp TV's:
1004, 1006, 1012, 1029, 1095
1111, 1112, 1113, 1122, 1171, 1173
Release the TV button and press the on-off button. If that doesn't work, press the device button and try the on-off button again. Continue trying codes until one works.
Another thing to try: Turn on device. Press and hold the button for device you want to program, press the on/off button and hold until the LED turns on, and then release both buttons. Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off. When the device turns off, stop pressing play. Press REVERSE, wait two seconds and continue doing this until the device turns back on. To finish programming, press and hold STOP until the LED turns off.
If neither of these methods work, the remote probably isn't compatible with your TV (manufacturing dates matter; newer tv's often don't work with older universal remotes). In that case, try for a exact duplicate of your TV's original remote.
I hope this helps.
Jul 19, 2010 | Sharp 19C140 19" TV
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a Sharp LC-52-d64u tv and it wont turn on
I have this same tv... Have you played any video games on it cause the xbox360 makes the screen blank... Put an hdmi cable in you tv and connect it to your cable box or dish box... this might fix the problem
Apr 06, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Nov 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp 32F640 32" TV works intermittently
The easiest thing to check is for loose conections because the unit is intermitant,the chassis should be check out for overheated areas and cracked solder joints in the power supply,horizontal driver and all the diodes and resistor off the secondary of the output trnasformer(flyback),if you are familiar with tv service this will help but if you are not too familiar be safe and call for assistance form a servicer.No doubt humidity can damage anything with time.
Oct 06, 2006 | Sharp 32F640 32" TV
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
