My Minolta x31 camera has a fault.
Cannot record a photo (black screen) can playback photos stored on SD card. Flash & monitor work as per normal.When in photo mode monitor is nearly black all over.Flash fires & appears to record photo. Nothing recorded.Please help
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
These SD or mini SD memory cards are normally used in devices such as cell phones and digital cameras. In cell phones they can be used to store and record photo images, music etc. In digital cameras they are used for storing photo images.
The memory card has most likely corrupted or the camera itself is faulty. Depending upon where you were holidaying this could be an intermittent fault due to temperature or humidity. It can also be caused if you have not followed the correct procedure for safely removing your SD card from your laptop (in Windows, click on "safely eject hardware" or from the "My Computer" window right click the SD card icon and select "Eject").
Try cleaning the card contacts using a cotton bud moistened with alcohol in case sweat, oil or grease has got onto them. If that fails then see if you can borrow another SD card, but this is risky as you may end up damaging the card so you may be better to buy the cheapest one you can solely for testing purposes (it's also worth asking for one on your local FreeCycle /Freegle groups as many folks now have low capacity SD cards with zero resale value which they have upgraded from and no longer use) . If the camera works perfectly then you know that it's most likely that the card was at fault and if not you definitely have to choose whether to get your camera sent for diagnosis and possible repair by Panasonic or whether to buy another one. Your camera is recent enough that it might still be under the manufacturer's warranty.
Regarding your existing SD card, it seems not to have recorded the images correctly or may not have recorded them at all. If the former applies, they *might* be recoverable but it needs specialist data recovery software which is not cheap (search "SD recovery"). Insert the SD card into your laptop and select the three black frames and click on "properties" to see how much memory they occupy. This will give you an idea as to whether there are approximately 90 images (3 x 30) there or not, but even if not the images could still be elsewhere on the card. You really won't know unless you invest in the required software to find out or by taking the card to a data recovery specialist (also not cheap). If you hope to recover any lost images then you must not use the card again as the data will gradually become overwritten.
The final option is to abandon all hope of the lost images, transfer the ones which you do have to your laptop (and back them up further to recordable DVD or a USB stick) and to then reformat the memory card in your camera. This option is only to be taken if obtaining a replacement SD card is impractical and if you wish to gamble that the fault was an unusual one-off. Only you can decide whether the risks of losing further unrepeatable photos are an acceptable alternative to the only certain (and expensive) fix of buying a new camera and/or memory card, although you could recoup some of the expense by reselling your current camera: it's up to buyers to ask questions ("caveat emptor") so don't mention the recent issues. Morally and legally this is fine as you don't actually know that the camera is faulty.
Sorry there's no definite answer here, but I hope that my reply will help you to isolate the cause or assists you in choosing your next course of action. If the fault is intermittent then they're impossible even for professionals to repair if they cannot reproduce the fault when testing the camera.
Good luck, and please take a moment to rate my answer.
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank: • Camera is off. • Batteries are not correctly inserted or battery-chamber cover is not properly latched. • Batteries are exhausted. • EH-62B AC adapter (available separately) is not properly connected. • Camera is in sleep mode. Press shutter-release button halfway. • Monitor is off. • USB cable is connected. • AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode. • Batteries are exhausted. • Red (!) lamp flickers: flash is charging. • Green (AF) lamp flickers: camera unable to focus. • Message "CARD IS NOT FORMATTED" appears in monitor: memory card is not formatted for use in your camera. • Message "OUT OF MEMORY" appears in monitor: insufficient memory to record picture at current Image mode setting.
Snap!! I'd come to same conclusion. Life has to end for all things
This camera's time has come. Thanks Doc
