Question about Garmin nuvi 200W GPS Receiver
SD Card slot Garmin nuvii 260
I have loaded a directions and coordinates on my SD card but, when I place it the SD slot it is not recognized?
Garmin Nuvi 260W actual moderl #
  • Anonymous Mar 12, 2014
    where is sd slot on nuvi 1490
  • Anonymous Mar 30, 2014
    I download tracking on micro sd card and it wont transfer to my computer. it is a garmin nuvi 50 lm
  • 26 Answers
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Posted on Jun 25, 2008
Micro sd card wont click into place garmin nuvi 2589
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Feb 28, 2016 | Garmin nuvi 2589LMT 5" GPS with Built-In...
Garmin nuvi 3760. I have downloaded North american maps to the SD card but the Nuvii doesn't recognise the SD chip map when I go to tool, maps etc. Help
Update your unit using Garmin Webupdater. The latest updated firmware allows the units to read all sd/microsd cards You can download garmin webupdater from here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run the program and follow the on screen prompts to update your unit.
Sep 27, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
I have a Garmin Nuvi 260. It keeps telling me I need to update my maps, but I do not have a USB port for this unit. How do I go about proceeding with updates?
the USB port is the same as the power feed port, if not have u a sd card slot, in which case down load from www.Garmin.com to card and place in gps. but the "warning" does not mean anything you will still be able to use the unit with out updates, the only thing it will not show is the newer roads / highways, mine is 3 years out of date and still working :)
Dec 29, 2009 | GPS
Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Jul 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
What is sd card slot used for?
The sd card slot is used when you buy update maps.
It's easier to update directly from the website, but if for some reason you can't, you can buy the maps on a sd card or on a CD. Then transfer to the sd card and load it.
Dec 27, 2008 | Garmin nuvi 260W GPS Receiver
Loading mp3 files to garmin nuvi 350
The device is not recognizing the file name. The Garmin GPS will only recognize MP3 files. Ipod (MP4) and other media files will not play. Converting the files to the MP3 format will correct the problem.
Jul 25, 2008 | Garmin Nuvi 350 Car GPS Receiver
Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
Problem loading maps to ubs card
The i3 comes with a 128MB micro SD card - first can you be more specific as to what you refer to as "not recognized"? Do the usb drivers install correctly and after installation is the i3 recognized by your pc once you hook it up with the USB cable? Is the micro SD card in place? Is it all the way in the slot?
Jun 29, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
873 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
