Control Panel message
51 PRINTER ERROR
Description
Beam error
Action Laser scanner cable connectors are faulty or laser scanner assembly is defective
Most likly it is the laser/scanner assembly. The motor is probably not
spinning at the right speed. You would need to find an old hp 4 no
longer working and switch the laser/scanner. It is the "black box"
located under the top cover. You would need to remove the right side
cover, the top cover, the left side cover and the output assembly.
Remove all the cables from the scanner retaining clips. Remove the
three cables plugged into the scanner and remove the four screws
attaching the scanner to the frame. When replacing the scanner make
sure the shutter control arm on the left front side of the scanner is attached correctly so that the shutter closes when the toner cartiridge
is removed. You could first try to remove the 3 connnectors and reset
them.
