Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Remove the Ice Maker too noise
Is it possible to remove the Ice maker?
    Genius:
  • 1,027 Answers
Yes, but by the fragmented question posted, I assume you object to the noise it makes. They can be turned 'off' by latching the tray sensing wire, simulating a 'full' tray.
Posted on Jun 20, 2008
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
REPLACE ICE MAKER PART AP4345120
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker.
On the new ice maker install the water chute (plugs in) and install the new ice maker.
Mar 13, 2012 | Refrigerators
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
Ice maker is splashing water all over back of freezer and it builds up til the fan starts to make noise if I turn it off and defrost the ice it will start up noise free til the ice builds again.
What is the model number of your unit? When the ice builds up, does the ice just build up where it is splashing or is the ice also building up behind the back wall of the freezer?
Thank you! Richard
Jul 21, 2011 | Refrigerators
Funny noises - sounds like it has to do with the ice maker The noises come and go; but, no ice is being made.
There is a tube , from the rear of the freezer , to the ice maker , which freezes closed , not letting water get to the ice maker . When it freezes , it is due to a " seeping " water valve , which means , this valve is not closing completely , letting a drop go thru and freezing in the tube . Replace the water valve ( the piece the wall water line connects to , on the back of the refrig ) . Also , remove the tube ( may have to remove the ice maker , 3 screws ) and defrost the tube .
Jan 20, 2010 | KitchenAid Refrigerators
Humming noise comming from around the ice maker
If you had your water cut off to the ice maker and didn't have the ice maker turned off, it was your ice maker. You turn it off by lifting the wire arm and leaving it in the up position.
Please rate solution
Sep 10, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
