Question about Toshiba Computers & Internet
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
  • geek63640
    geek63640 May 11, 2010
    What make/model burner do you have, and what program are you using to burn your media with?
    What brand of disks are you using? Have you successfully burned other disks? What speed are you trying to use.
    My gut response is that you've got a bad batch of disks. Try another brand of disk at a slower speed.
    Please respond back with your answers so we can help.
I had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
Posted on Jun 26, 2008
Trying to burn a dvd and i get this error please advise Module sfmmcx.cpp Line 2240 A medium error occurred. A Power Calibration Area error has occurred.
Your software and hardware are conflicting. Need exact problem for an exact answer. What type of burner, what type of program or software is trying to burn.
Feb 18, 2011 | Computers & Internet
Had a drive that did the exact same thing myself. You'll need to replace the CD drive. It's cheaper than having it repaired.
May 30, 2009 | Intel Computers & Internet
The drive reported an error: sense key-medium error sense ode= 0x0c write error iomega 48x24x48x cd/rw usb burner
this is almost certainly a dirty lens on the writer. clean it with a lens cleaning disk.
May 07, 2009 | Iomega (32885) CD-RW Burner
Dvd burner problem
use different software writer:
and also update your DVD Firmware and BIOS
Mar 20, 2009 | LG LAC-M6500R CD Player
Power calibration error
In the past some burns did not like some makes of cdr's. Ask a friend for a blank cd from a differant manufactor. And be sure that your burn software is set to use the right drive.
Apr 03, 2008 | Computers & Internet
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
Mar 28, 2008 | Computers & Internet
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link:
I Hope this helps,
Feb 12, 2008 | Ahead Software Nero 6.0 (60045) for PC
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
this can be a complicated issue to solve, so go to the link below and see if there is any advice that is rellevant to you
Jun 03, 2007 | LG (8526B) CD-RW Burner
Numerous errors when attempting to burn dvd's
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Nov 11, 2006 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Computers & Internet Logo
444 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
