Question about AKG SR40, 900M Professional Microphone
AKG MIc My AKG wireless mic was broken someone turn the mic and boke three cables. Can some tell me in what order do they go so that I can soder them back again. the colors of the cables are red, blue and black. thanks
  • 8 Answers
SOURCE: AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Posted on Jul 13, 2007
SOURCE: akg mic buzzing
constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Posted on Nov 28, 2008
Cableg Eye
  • 22 Answers
SOURCE: AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Posted on Oct 28, 2009
SOURCE: how can you open an AKG 220 perception mic to
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
Posted on Feb 03, 2011
I Have 2 recivers and 4 mics but can't use all 4 only 2 works
A wireless mic receiver will only reliably work with one mic at a time. For that reason, you need to have 4 receivers in order to use 4 mics simultaneously. You could switch back and forth between mics by setting them to the same frequency and turning them on and off, but they will not work reliably if they're both on at the same time.
Nov 10, 2013 | AKG SR40 - UHF Receiver SR4054 Microphone
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Akg c3000b Low output all of a sudden
Buy the Caig Labs De-Oxit kit and clean up/treat the XLR connections on the mic itself.
Apr 27, 2017 | AKG C3000B Professional Microphone
Samson CO3U USB mic pattern selection switch broken
I have not used that particular mic, but have a AKG 414 which offers the same three patterns and there are three distinct and separate settings on the switch. Maybe take it back into the store where you bought it and ask for clarification there? Hope this was helpful. Peace
Dec 24, 2008 | Samson Audio C03upak Co3u Microphone with...
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
Akg mic buzzing
Jul 23, 2008 | AKG SolidTube Professional Microphone
Mic repair
Oh sorry, it was an AKG c418. However, shortly after i posted, i stared at the thing long enough and managed to get it apart, fix it and put it back together. thanks
Feb 28, 2008 | Audio Players & Recorders
AKG SR40, 900M Professional Microphone Logo
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
