Question about Danby DDR606 Dehumidifier
Overheating Hi was just wondering if the filter is dirty.. will the dehumidifier blow hot air and the top of the machine get really hot? Thanks.
  • chinadolls Jul 01, 2008
    Same problem here, with the same model.  But the filter was clean.
    I turned it off, and unplugged it.  It was starting to smell like smoke, but there was nothing else obviously alarming.  The fan motor did not sound any different.
  • nickc389 Oct 15, 2008
    Same thing, it appears to work the same, but get very hot on the top. Sometimes it smells hot, but no difference in how it sounds etc.
Same problem, I cleaned the filter etc. seems to run ok, but gets very hot on the top and sometimes smells hot. No signs of burning etc.
Posted on Oct 15, 2008
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
The top of the unit has alot of condensation on it. so i am wondering if its freezing up inside. Have set point at 55% what can i do to fix the issue
A little condensation is not something to worry about. But, a lot can be caused by a dirty or clogged air intake filter. Which can also cause the cooling coils to freeze.
Turn the unit OFF & unplug it, before removing the filter for cleaning.
Also, maintain 12" to 18' of clear air space all around the unit.
If the unit is in an extremely moist or damp environment, 55% is not really a low setting. 35% would be more appropriate for this type of environment.
Hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | LG LHD459EL Dehumidifier
After an hour, the refrigeration unit begins to freeze up. Condensation appears on top of the dehumidifier cabinet. I have eliminated all obstructions to air flow, including the filter. What can I do?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Sep 10, 2011 | LG LHD45EL Dehumidifier
My GE basement dehumidifier is overheating. The bucket still collects water and the fan works, but the unit is putting out alot of heat. My dad is visiting and has taken the whole thing apart. Any...
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | GE AHG40LJ Dehumidifier
I have had the machine on for 5 days on high and have extracted less then a 1/4 inch of water. The back side of the machine is hot and blowing hot air - the motor runs but does not extract water Is it...
Possibly, but I doubt it. Because, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. Operator Error - The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a
mechanical unit, set the manual control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
Not all of the above will apply to your situation. But, they are good know for future reference.
Jul 31, 2011 | Whirlpool AD25BBK Dehumidifier
MY dehumdifier is blowing warm air ,Is there a fitler that needs to be cleaned and how is this done ? Model 3fdl5051 50pints
It's not unusual for a dehumidifier to blow warm air. As it may be in defrost mode. Even so, they still blow warm air.
The model number you furnished is slightly helpful. Knowing what brand it is, would be even better.
Never-the-less, the filter should be located behind the front louvers of the unit. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the water collection bucket and look up inside the bucket holder, just behind the front louvers. You may see a plastic pull tab handle. If so, that's the filter frame. Pull it straight down and out.
If you didn't find it there, look on the right hand side of the unit, just behind the louvers for what looks like a a flip open door. If you see that, flip the door open and remove the filter.
The filter can be cleaned using a vacuum cleaner or if it's really dirty, wash it in warm water and dish washing liquid. Thoroughly rinse and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire Dehumidifiers
The dehumidifier machine is running however, not producing any water in the upper bowl.
The problem you're having with your dehumidifier, may be the result of one or more of the basic, but solvable problems and solutions listed below:
1. The Humidity Extraction Level is set to High. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Remove, inspect the filter and clean if necessary. It it's a
Washable Filter, allow it to thoroughly dry before reinstalling it.
3. Obstructed Air Flow. A minimum of 12" to 18" clear air around the entire unit, must be
4. The ambient air temperature at floor level is between 40 - 60 degrees F. This is particularly true in
basement applications. The air temp at floor level is colder than the air temp at shoulder level.
Dehumidifiers don't work well in that temperature range (Unless, it's a Low Temp model). Raise
the unit up off the floor on to a sturdy table, counter top, etc, that can handle the weight of the
unit, plus a full tank of water.
If you troubleshoot the 4 things listed above, it may quickly solve the problem. Please let me know. Thanks.
Jun 18, 2011 | Danby DDR600R Silhouette Dehumidifier
Unit will do a small of amount of dehumidifing however the unit gets very hot on top and blows very hot air out of rear. Could this be a lack of freon or whatever is used and comprssor getting hot??? ...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
May 25, 2011 | LG Dehumidifiers
Dehumidifier not removing moisture
could have overheated the compressor if the filter was really dirty and blown it
Jun 20, 2009 | Maytag M3DH30B2A Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Danby DDR606 Dehumidifier Logo
1,026 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
