Question about Nakamichi SoundSpace 5 Shelf System
NAKAMICHI SOUND SPACE 5
I HAVE A WORKING SYSTEM, MISSING ONE SPEAKER
AND A PIECE OF BACK COVER WHERE BUTTONS
ARE (JUST NEEDS NEW BACK COVER.
WILLING TO EITHER BUY BACK COVER AND ONE
SPEAKER OR SELL UNIT TO YOU FOR PARTS.
ROBERT.LUDWICK@YAHOO.COM
  • ralph keefer Jul 11, 2008
    Do you want to sell the power supply to your soundspace 5. Let me know my email is ralphwkeeferjr@yahoo.com
    Thanks
  • gigyblu Jul 29, 2008
    I have the Nakamichi Sound Space 5. After a few falls, my right speaker has static. I'm thinking a new speaker and new cable that comes with it may solve my problem.
    This is my first attempt at solving this issur.
How much do you want for it. I could use the power supply from your soundspace 5.
Posted on Jul 11, 2008
I have Nakamichi CMS-5 and cassette deck DR-5. How i configure it to connect with Harman Kardon BDS 277. In CMS-5 there are 4 Jacks that read Processor, What is the purpose of those jacks. Not a singl
There's not a lot of info on the web about the specs and sockets on a Nak CMS-5 or the RE-5 reveiver that's part of the system. So some of this is based on the tiny fragment of information you provided.
The HK BDS277 has no outputs, only inputs. So however you decide to connect, the only way that things will work is if sound signals come from the Nak and go to the HK so that the sound comes from the HK speakers.
If the Nak has processor sockets as you have half suggested, then they act as a break point between the NAK pre-amp which does source selection and the Nak power amp that provides the muscle to drive the Nak speakers. Disconnecting the links from Processor Out/Processor In with interrupt the signal flow. You'll then be able to connect Nak Processor Out to one of the line inputs on the HK.
Any sources already connected to the Nak will then have their signals routed to the HK. The Nak speakers will be silent.
I hope this helps you.
Oct 19, 2014 | Nakamichi CMS-5 CD Shelf System
Nakamichi SS-5 humming noise at stand-by nmode
Nakamichi service center in New Delhi. call +91 9871371720
Jun 26, 2009 | Nakamichi SoundSpace 5 Shelf System
Soundspace 5 Right Channel Problem
Some thing has broken in the unit! Switch speakers around to make sure its not a blown speaker! If its not the speaker then your right channel control will need replaced!
please rate answer!
Jan 24, 2009 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Soundspace 5 Speaker Covers
if you let me know how to set up the presets on the sound space 5
I'll give you the green set and the blue set. (Shipping within reason)
Oct 24, 2008 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Sound Space 8 System
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
Power and lcd
If you are comfortable with opening up your system you could order the LCD from the manu. and install the new one. As far as the power goes. you may have knocked a connector loose (easy fix) or you either cracked the circuit board or broke a solder connection. You can do a visual once you have the unit open to see which it is. Again, if you are comfortable with a solder iron then reflow the broken solder connection or take a small piece of wire and repair the broken circuit board connection. (using the wire and solder to create a new "bridge") If you are not comfortable with this and it is not a loose connection you will probably need to take it to a reputable repair shop. The manu should have a list of authorized repair shops.
Jan 12, 2008 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Sound space 8.5 Home theatre system
check www.dalbani.com and see if you can get these parts.good luck.greeting from Belize my email is nicodhem@yahoo.com
Apr 04, 2007 | Nakamichi SoundSpace 8.5 System
Nakamichi SoundSpace 5 Shelf System Logo
258 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
