Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
No wireless light
I have a Linksys WRT54GX2 router connected to a Motorola SB5101 cable modem. On the display only the power, internet, and [connected] ethernet ports are lit up. The wireless light will not come on. I've tried adjusting settings by accessing the routers ip address (192.168.1.1) but nothing seems to work.
One thing occurred to me. Could the modem be doing all the "thinking" for the router? I had a similar problem with a DSL modem once. I connected directly to the modem (192.168.100.1) but could not change the settings (and also I don't know what to change anyway).
Any ideas? Any help appreciated.
  • Are you sure you are plugging in the LAN cable coming from the modem into the WAN Port (Labelled "Internet") on the router or is it getting connected to an Ethernet port (Marked from 1 to 4)??
  • Linksys Master
  • 6,487 Answers
If the wireless light is of on the router it only means that it has a problem, Try to turn off teh router to 10 seconds and check if still no wireless light , if still no wireless light you may need to press and hold the reset button of the router for 15 seconds and that should fix the problem on it.
hope that helps........
Posted on Jun 20, 2008
  • 298 Answers
Have you tried to check the IP address that you are getting from the router on your wired computers? If they are getting an IP address of 192.168.1.10x and the DG: 192.168.1.1 then that is the right address to get in to the router. Did you try to ping the address? did get replies? try to also disable the firewalls on your pc.
3 Suggested Answers
le_kash
  • 106 Answers
SOURCE: can't connect to my linksys
  • make sure the DHCP server is enabled on your router
  • your LAN TCP/IP should be set to "obtain IP address automatically"
  • check DHCP client table in your router if there is anyone trying to connect to your router illegally
  • try to enable MAC filtering on your router wireless security
Posted on Oct 02, 2010
puertobori
  • 7733 Answers
SOURCE: Hi, i am johnson, i
go to Lynksys Support and Services
thumbs back!
Posted on Oct 28, 2010
I have a linksys wrt54GX2 wireless G router and I would like to use it as an access point to pick up our internet signal from downstairs. The modem in use is wireless motorola SBG900. I have a desktop and...
With that particular model you wont be able to use it as a wireless bridge. You can however run an ethernet cable from the modem to any point in your house. the SBG900 i believe has wireless built into it, so you may need up with 2 wireless networks.
Hope that helps.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
I cant get my motorola sb5101 surf board cable modem to connect to a belkin g wireless router. the light on the belkin flashes orange when i try to connect it to the modem but no internet connection
I have a similar problem. The common denominator seems to be the SB5101. I have a brand new Belkin Surf 300N, same issue. The modem will not give DHCP to the router. I can connect fine via ethernet to the modem directly.
This modem seems to be a dinosaur.
May 21, 2010 | Arris SURFboard SB5101 Cable Modem
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Hi I am going to hook up a linksys wireless router and i need help. do i just hook it up or do i have to do something to the modem first?
all you need to do is to connect the ethernet cable to the internet port on the back of the linksys router and then plug the routers power cord into the wall and you should be ready to go.
Jan 03, 2009 | Arris SURFboard SB5101 Cable Modem
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Moto modem to Linksys wireless router
You have to reset the modem from behind (little pin hole) with the modem and router not connected via ethernet, the let it restart and reset the router after both are reset connect the ethernet cable between them.
Nov 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
WRT54GX2 Wireless-G disrupts both laptop and desktop internet connections
it might be because of interference...no issues dont worry about that...
JUst follow these steps and the issue will be resolved....
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STEPS FOR WIRELESS CONFIGURATION
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or
anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on
save settings.it will say like "Settings are successful"click continue.
8,to set the password for ur wireless network...below wireless tab in the black bar..u will
find a blue bar which says "wireless security".click on "wireless security". Security mode
should be "WEP"..Default transmit key should be 1.wep encryption should be 64
bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur
telephone number will be ur password for the wireless connection)click save settings and
continue..
9,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless
signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
Jun 01, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Need tech advice
No and why doesn't your internet provider... provide a cable modem?? Did you just ask them to enable broadband internet service? So now you'll have to provide your own cable modem.
If what you say is correct you need a cable modem like a motorola surfboard from BestBuy.... then the cable modem plugs into your Linksys router and your PC's plug into the linksys router also.
http://www.bestbuy.com/site/olspage.jsp?skuId=8229044&st=motorola+surfboard&lp=1&type=product&cp=1&id=1168043113583
May 05, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
I have a cable modem, Motorola SB5101, Nd need to connect my linksys wireless router.
If this is a first install of a brand new Linksys router:
Just plug your cable modem to the back of your linksys router's internet port, then plug a computer to Port 1 on your router, type http://192.168.1.1 in your internet browser on the computer connected to Port 1, you will access the setup page of your linksys router (leave the user name field blank and type admin as password)
Now you can go to http://www.cas411.com/ShowArticle.aspx?ID=68 to setup your wireless securely, you do not want to just leave it at its default settings, as anybody could then use your internet access or worst, check what you are doing on your computer.
Let me know if you need more help!
Apr 25, 2008 | Computers & Internet
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
177 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
