Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Spray arms not turning
The small arm on the ceiling of the unit turns, but the arm on the top rack and the very bottom arm are not turning. There is water coming through, but they do not rotate. I have checked to make sure there are no obstructions, etc.
  • Fullerton67 Jun 20, 2008
    There is no hum at all. Let me pull the spray arm when it's finished running. Does the arm just lift out?
  • 2,071 Answers
It seem the problem is in microswitch thats control the mechanism of the motor to move the arm,,you better checked it out that switch or change that..the failed of synchronization of movement of the arm is cause also in the system,just try this also go to menu setting and default the factory setting ,its to reset try this option..
Posted on Jun 20, 2008
  • LORETO LACARON
    LORETO LACARON Jun 20, 2008
    it can be lift but do it gently...
    Sergeant:
  • 243 Answers
If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck. You may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
to check the motor you can follow these steps.
Pull out the spray arm and remove pump cover, loosen the torq screws.
Sponge out all the water by the half round pump cover, then remove pump cover and remove the rest of the water.Remove any thing jamming the impeller.
If nothing found, turn water supply off and turn dishwasher on. Open dishwasher door and observe motor impeller. If turning the wrong way, you have a polled sidewinder motor.You will need a new one.
let me know how it goes.
  • Nathan Ayers
    Nathan Ayers Jun 20, 2008
    most of the time it just has a simple Latching system or even a torq screw.
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
Not dispensing detergent properly---not getting top rack clean-------could this be a problem with the kitchen drain? I clean the filters often. I have Model SHU43C Thanks for the help, Barbara...
Hello Barbra. Not likely a drain problem because the machine is evacuating of the water from the sump. The bottom rack i assume is ok.
So the top rack in not doing it's job.
1.......clean out all of the timy holes in the spray arm.
2.......make sure there is nothing stppind the top arm from turning
give it a flick to see if it spins around freely
3..... tall object in the bottom can stop the arm from turning.
4.......some bosch machines have a divertor valve to alternate the water from the top to bottom racks. The valve. if faulty can be stuck in the bottom position not allowing the top arm to turn. Yopu can check this by turnint both arms to line up with easch other, say both arm ends pointing to you . then close the door and start the machine. after a short while of hearing the water swishing, open the door and see if the arms ahve moved. if both arms are turning then you know the divertor valve is ok. Even if your model does not ahve a divertor valve this is a good way of testing the spray arm operation.
Always use good quality soap and avoid tablets. use powder and make sure you have rinse aid in the dispenser.
Aug 06, 2010 | Bosch Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
Dec 21, 2009 | Kenmore Dishwashers
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
172 people viewed this question
Top Electrolux Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
