Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer not heating
Can't you just jump across the thermal unit and expect the coil to heat up?
    Novelist:
    Scholar:
  • 70 Answers
No. And even if you could it would not be safe.
Today's dryers are full of safety devices and interlocks that insure that someone cannot just jumper the unit. Also, if you were to do this you might cause another component in the system to fail. Most of the units today use low current, low voltage devices that are microprocessor driven. A short across the thermal unit might not cause a problem but more than likely the microprocessor will shut it down because it doesn't expect a short other than as a failure mode.
There is possibly something else wrong with your dryer if the coil is not firing. It might be a burnt out coil. The best test is by removing the wires from the heating coil and using an ohm meter (ohms scale on an inexpensive multi-meter) to see if it is "open" (burnt out). If it is then replace it. I've done it a couple of times but would rather pay someone else to do it now.
Posted on Jun 22, 2008
My offerer istaking lingers slinger to dray load. The filter is cleaned after each loadandthe unit does heat up but drying takes as many as six cycles. Any diagnostic ideas? B
Hi brentf524...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Sep 09, 2011 | LG Dryers
No heat . heating element looks good no coils broke. replaced thermal fuse and themostat .now what?
Hi mikedissnts...
Check your Wiring
Sep 08, 2011 | Amana Dryers
Is there a way to check the thermostat on the heating coil of a Bosch 500 series dryer with a meter? I've got no heat but I have 240 to the unit and the heating coil has contiunity. The thermal...
Hi mk3327...
Try these solutions to your problem:
Check your Wiring
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse, by removing the wires from each of the two terminals and checking each terminal on the thermal fuse,thermostat,thermistor, ect once you have the wires removed.
Then you do not have to tape the wires together as described above.
Sep 08, 2011 | Bosch Dryers
I have an amana electric dryer. Will not heat up. i checked thermostat for continuity it is good. i checked the two thermal fuses for continuity they are good. I even jumped a wire accross all three...
Hi pitsburg69...
you have probably already checked some of these...
Check your Wiring
Sep 04, 2011 | Amana Dryers
Hotpoint aquarius cdt00 tumble dryer not heating up
Hi c morgan20...
I am guessing that your unit requires you to empty the bin manually.
Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air.
If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. You may want to check the bin switch if you have one.
Here are a few more things to check:
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 24, 2011 | Dryers
I have a Kenmore Elite HE5 electric dryer and the unit runs but no heat output. I do not know what component has gone bad.
Hi boyd larson...
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jun 22, 2011 | Kenmore Dryers
How can I tell if the heating element is gone in my Samsung model DV203AES dryer?
Hi k jeffrey510...
Before you jump right to the heating element you may want to check a few of the things below.
The way to check the heating element is included in the instructions below:
Check your Wiring
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.<<<<<
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Jun 04, 2011 | Samsung Dryers
Dryer not heating up but is otherwise running fine.
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Jan 03, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs but no heat.should I check the thermal fuse first? Model LGN 2000JQO
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
If the coil is not your problem then you should check the thermal fuse/thermistor. An easy check for them is to remove the wires from the fuse/thermistor and tape the wires together, if the coil heats then replace the fuse/thermistor.
DO NOT LEAVE THEM TAPED TOGETHER AFTER THE TEST.
If you do then you could cause a fire because you have no safety.
Good Luck,
Hope this helps
Oct 14, 2009 | Whirlpool LGN2000LWH Gas Dryer
The dryer runs, but there is no heat. Gas is
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Aug 20, 2009 | Kenmore 700 6972 Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
