Question about Dryers
I wired a dryer and it works for a short time and then one of the 30 amp fuses blows. Please help.
    Sergeant:
  • 243 Answers
This is typically your ground wire. I assume by what your saying. That you rewired the outlet required for your dryer.
Did you just rewire the plug? or did you rerun the whole outlet from the Main circuit breaker.
I would first test it with a multimeter to ensure the ground is correct.
also if you rewired the whole outlet to the Main circuit breaker what gauge wire did you use?
i doubt the drying unit itself is causing a short its just the draw off the circuit. and the ground being improperly grounded. I had to rerun my ground wire for my dryer after moving into my new home.
i hope this helps give you a idea let me know how it goes. If you need more help feel free to add comments as i will be glad to assist you.
Posted on Jun 20, 2008
  • Nathan Ayers
    Nathan Ayers Jun 20, 2008
    what was it? were you able to Fix it?
30 amp fuse keeps blowing on my Honda deauville 650
30 amps seems too high for any bike.... But any time you keep blowing fuses...there is a bad short somewhere check all the wiring for that feed; worn wires, bad connections, and faulty equipment on that feed service.
Good Luck
Jerry
Jun 10, 2016 | 1998 Honda Deauville NTV 650
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
1996 dodge ram 1500 keeps blowing 30 amp engine control fuse
Look for a part of that wire cable that is rubbing on metal somewhere or that some mechanic pinched under a bolt or drilled a screw through. It may take some time but the closer you look at that wire from end to end the faster you will find the problem. Blowing a 30 amp fuse means something is shorting out pretty good so go find the short.
Oct 19, 2013 | 1996 Dodge Ram 1500 Club Cab
1997 Harley Ultra Classic 30 amp main breaker pops while riding. Also blows 10 radio power fuse
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 19, 2012 | Harley Davidson FLHTCUI Electra Glide...
Main 30 amp fuse keeps blowing when i plug the 4 wire fuse top back on after replacing 30 amp fuse. any suggestions
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
keep blowing the 30 amp fuse
main fuse keeps blowing
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Jul 14, 2017 | 2003 Honda VT 1100 C Shadow Spirit
Dryer not heating
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | KitchenAid KEHS01P Electric Dryer
The dryer isn't getting hot. I know there's a
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
20 Amp FP/ASD Fuse #21 keeps blowing.
hmm. lt look like there are poor joints in your wiring specially the groung wire. check the diagram of your auto. check the unit diagram for which the fuse blows. usually the fuse blow when there is a short circuit. if you look around you will find it.
good luck
ehsan.
Jan 20, 2009 | 2002 Dodge Neon
LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
Jan 02, 2009 | LG DLE2514 Electric Dryer
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Dryers Logo
130 people viewed this question
Top Dryers Experts
