Question about Kitchen Ranges
Thermador Burners Won't Light
I did clean the inniter tips and even replaced one just in case that was it. I also cleaned the burner units. The burners work fine if I light them with a lighter.
  • 1 more comment
  • mtschieber Jun 20, 2008
    I think I did wire it up correctly.
  • WSBERMAN1 Jun 22, 2008
    JUST TODAY ALL IGNITERS WON'T EVEN CLICK...GAS IS COMING OUT THOUGH.
  • Anonymous Jun 30, 2008
    range burners have gas flow, but igniter not functioning at all.. no clicking, no spark, nothing.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Have you replaced the igniter the same as the specs needed to be installed..?
Posted on Jun 20, 2008
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
My burners won`t click to light
What is the complete model number of the unit?
Dec 15, 2012 | GE Profile 30" Slide-In Gas Range -...
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Thermador model RDF30RS burners won't light
Hi, there are two small circuit boards on those burner controls. They are called potentiometers. There was probably a boil over or spill at some point. They are notorious for failing. Hope that helps.
May 04, 2017 | Kitchen Ranges
Intermittant/interrupted ignition device
The problem here is that the port holes in the burners are probably clogged. Clean ALL burners by taking a toothpick and unclogging the port holes. As for the position problem, if you have independant igniters, as some models do, you may need to replace the igniter. Remove knob and remove igniter,(white rectangular item with two wires) remove wires and replace.
Sep 08, 2008 | Thermador Cooktops
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Mar 20, 2008 | Thermador PSC364GDZS Gas Cooktop
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
