Question about Cell Phones
Phone will not turn on at all. screen lights up white when charger is plugged in. serial number on battery, charger & phone are all different.
    Brigadier General:
  • 7,752 Answers
You should take the phone to a mobile service center and have them service the phone for you and replaced the cables
Posted on Jun 20, 2008
My phone will not charge
You probably tried taking the battery out and using an eraser, clean the terminals of the battery, replace do not power phone on, plug in charger and see what happens.
Aug 03, 2017 | Alcatel Lands Phones
Where do I find my serial number from a sumsumg galaxy s i500 ?
Turn the phone off. Turn the phone over. Remove the back cover. Carefully remove the battery. The serial number and mac address ar printed on the tag under the battery. Write it down. Double check all alpha/numbers. Replace the battery. Replace the back cover. turn the phone back on.
Hope this helps.
Bob
Sep 10, 2011 | Accessory Export Samsung Fascinate /...
My friend has a blackberry, he dropped it last night and he said it worked for a hour then it turned white, i took the battery out, no red light popped up no white screen or anything, i plug it into the...
There are several online stores that sell replacement screens and some even supply the tiny screwdriver necessary to open the phone. Just search blackberry replacement screens. You may be lucky and find a youtube video showing you how to do the job
Jul 28, 2017 | Valor Fits Blackberry Curve 8300 8310 8320...
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it...
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
Jun 06, 2010 | RIM BlackBerry Pearl 8100
My lg vu has a white screen with a folder and a red circle with a exclamation mark and says emergency download an i cannot do anything only way to turn it off is to take the battery out
PLUG YOUR PHONE INTO THE CHARGER WITHOUT THE BATTERY. PUT CHARGER IN AND OUT OF PHONE WHILE CHECKING IF THE SCREEN HAS CHANGED. DO THIS UNTIL SCREEN CHANGES (TAKES ABOUT 5MINS MAX) TO THE MAIN AT&T PAGE. NEXT YOU HOLD DOWN THE POWER BUTTON AND AS SOON AS IT BEGINS CHANGING SCREENS CONTINUOUSLY PRESS THE CALL BUTTON. THE PHONE SHOULD BE BACK TO NORMAL AFTERWARDS. THE ONLY THING IS ONE OR TWO BUTTONS MAY WORK DIFFERENTLY.
Dec 24, 2009 | Cell Phones
My phone won't start on!
Nokia sometimes has a glitch where if the battery is too low it will not start properly again. Let it charge for some time when turned off - a couple hours, so it has enough battery power then remove the battery for 5-10 minutes, put the battery back in and try start it. What this does is re-sets the phone so it can start again. Also if there are problems during use that solution usually fixes it as well. What is happening is due to a low battery it tries to resume where it left off and cannot load itself properly to do so. Letting it go completely dead with no battery for a few minutes lets it drop it's old info and reload it's info to work again.
Oct 19, 2009 | Nokia N75
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Phone went off only blue light showing
well plug the charger into the phone with the battery still intact.....then remove the battery while the phone is still plugged in. then unplug the charger and plug it back in........place battery back into phone and then power it up. That worked for me.
Feb 01, 2009 | HTC G1
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
Aug 08, 2008 | HTC TYTN GSM Phone
Dead Phone
I have the exact same problem. It is completely dead but sometimes when I go to turn it on the screen will flash white and the speaker will pop. I tried different batteries and different chargers and I have no idea what the problem is.
Mar 10, 2007 | Motorola Mobility V265
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
