Sir i have a nokia 3220 and the menu key doesnt work often times i already clean the key pad membrane what should be the problem and the solution? thanks
On the main screen type: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This ...
Switch on the cell phone. Factory Reset NOKIA 3220 · Now goto Menu -> Settings -> Restore Factory Settings. · Then please enter your security code. * The default ...
Missing: c- ‎' Must include: c-
How to Hard Reset Nokia 3220 · Press and Hold * key + 3 key + Call button + Power button until you see logo Nokia. · Then release all hold buttons. · It will ask ...
Missing: 2 ‎' Must include: 2
hell there! I want u to try this small antidode get the key pad membrane cleaned which is under the key pad . coz some kind of carbon forms after a period of time or liquids to can cause this too.
lastly if no change change the key pad membrane .
Get a technician to do this for u
remove its keypad, wash it's contact surface(which is made up of rubber) with soap and water gently then dry it thoruoghly , refix it n u r problem is gone :)
please do care to rate my solution . thx
Sir I have nokia 3220 i have problem problem connecting it with pc. I have also installed nokia pc suit but it it shows that no phone is connected.Should i install drivers or somthing else please help me on this
F1
Defective touch pad or membrane
Replace touch pad or membrane (usually the touch pad)*
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
sir you have to send it to your nearest shop to clean the keypad membrane maybe its been damage by corrosion sometimes our hands gets sweat or talking someone for an hour our ears get sweat. you don't know that the sweat goes through the keypads.
