Question about Emerson CKA1000 Clock Radio
Won't display time. Error message 20 ne
The Emerson Atomic Clock won't hold the time. It continues to display 20 ne message despite the reset attempts and position changes. I also replaced the battery.
  • challpub Jul 30, 2008
    We have the same problem.  This happened after a bad storm in which we lost power for 30 minutes or so.
  • Anonymous Oct 12, 2008
    I have the same problem, however, figured out that it was displaying "Zone". Does anybody know...is the clock a lost cause, or what?? We've tried multiple things as well.
It's not displaying 20 ne - It's asking for the time ZONE . . .
Posted on Jul 08, 2008
It is asking for the time signal. Try moving the clock/radio to another area in the house. The atomic clock signal from Boulder, Colorado is on a frequency of 60 kHz. Unfortunately house current 120 volt is also 60 kHz and may be interfering with the signal. Hope this helps
Posted on Jul 29, 2010
My new Kenmore Electric Range, model 790.9419, purchased July 18, 2014...The clock no longer works. I press "clock", the code CLO appears; I set correct time; press START and the display goes blank an
That's an enegy saving "feature" - the ability to turn off the clock. Usually (in most models), you can turn the clock display back on by pressing and holding the clock 10 to 15 seconds.
Sep 17, 2014 | Kitchen Ranges
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
I have a model CKA-1000 with the 20 ne problem. Last night I pressed the time zone button like it said in the forum and the correct time popped up. This morning, however, it was back at 20 ne. I again...
It is asking for the time signal.Try moving the clock/radio to another area in the house. The atomic clock will pick up the signal from Boulder, Colorado is on a frequency of 60 kHz. Unfortunately house current 120 volt is also 60 kHz and may be interfering with the signal.
Hope this manual will help you out solving the problem
The CKA1000 series will have same manual.So you can use this manual for reference.
Click here downlaod manual1
Click here download manual2
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 08, 2010 | Emerson CKA1000 Clock Radio
S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Dec 12, 2008 | SkyScan 86709 Atomic Wall Clock
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
Aug 15, 2008 | Honeywell RC182WR Atomic Alarm Clock - Red
My cka 1000wants to display 20 ne most of the time.
The manual recommends pushing the time / set middle large button once or twice. Have the antenna as far away from the clock as possiable. In the NE NY & Boston it make take a few days due to weak signal. It helps if the antenna is by a non metal window sill. If that doesn't work put it on the west side of a house and after a few days it will set. After pressing the button one of 4 dashes will appear in the display. This means it has confirmed the signal and the clock will set. ( I just found my missing manual and reset it all myself).
Jun 10, 2008 | Emerson CKA1000 Clock Radio
Savings time
This is more of a Clarification than a solution.
I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday in October, but starting in 2007, it is observed from the second Sunday in March to the first Sunday in November, adding about a month to daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
Mar 17, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
Emerson CKA1000 Clock Radio Logo
586 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
