Question about Kenmore 15912 Built-in Dishwasher
Kenmore Dishwasher- Thermal Fuse Problem?
Hello-
My Kenmore is around 2 years old and recently it has just stopped working mid cycle and the keypad dies out.
It seems to power back on indescriminately and when it restarts (resuming where it left off) it can stay on for <1 minute or run for 10.
I looked at the circuit diagram and ran the diagnostic but it dies in the middle of that too.
I called an appliance repair guy who, as a result of being stuck in traffic, tried to help me self diagnose it- he seemed to think the computer/circuits were all fine and that it sounded like a fuse was tripping (or a heat sensor?).
However, I can find nothing labeled fuse on the schematic. I'm betting he's right as now that I think about it, it seems to power back on after it has cooled off. I cannot seem to locate the thermal fuse...!?
All connections are snug on the board as are the connections from the dishwasher to the power source. There is no corrosion on the board.
I'm trying to discern my model number but the front of the manual lists the following: 665.1602, 665.1702, 665.1603, 665.1703, 665.1622...
I'm hoping it's something simple. Any ideas? Thanks in advance.
  • 131 Answers
SOURCE: kenmore dishwasher model 63991 (10yrs old)
If the display works, but the machine doesn't fill, wash, or pump out, the control board is the only component that could cause all these symptoms.
Posted on Mar 10, 2008
SOURCE: Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Posted on Apr 10, 2008
SOURCE: Where is the thermal fuse for Kenmore 665 11073342 dishwasher?
The thermal fuse is located in the front control panel where the circuit board is. You need to remove 4 screws(depending on the type of dishwasher you have) and you will see it. Make sure you change everything not just the fuse but the new wires also.
Hope this fixes your problem
Posted on Feb 20, 2009
SOURCE: kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Posted on Feb 26, 2009
pride applia
  • 232 Answers
SOURCE: I have an 8 year-old Kenmore 665.16912 dishwasher.
if all are really good then the only thing it con be is the display (8269205) $25.00 part, if it's bad dishwasher wont run
Posted on Dec 25, 2009
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Dryer stopped in mid cycle (Kenmore)
Check the door switch. You should hear a click when you push and release it. If no click, replace the switch with this part.
If the switch is good, then the thermal fuse has gone out. Here is a link to that part.
Here is a video to show you how to replace the door switch.
Here is a video tho show you how to replace the thermal fuse.
Oct 16, 2012 | Kenmore Dryers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher 587.15159400
patrick c smtih
phon 951 805 5187
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
I have a kenmore dishwasher and it stopped in the middle of a cycle and water is in the bottom. No response from the dishwasher, plug is ok and not tripped. Is there a reset button or not?
When the dishwasher stops in mid cycle and there is no console lights illuminated, then more times than not the thermal fuse has gone out. The thermal fuse is located on the power supply board which is located inside of the console. you must remove the console in order to gain access to the power supply board. the thermal fuse is white and has to wires connected to it. a black wire and a black wire w/white stripe. disconnect the power at the panel box first, before you start. you then remove the old fuse, by "plucking it up" w/ a small flat head screw driver. then you remove the two wires connected to the fuse and place the new fuse in the spot ot the old fuse and place the wires on the new fuse. any order of placement will work. There is a fuse kit that will handle the electrical surges that may have cause the fuse burn out in the first place.
Apr 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 15912 Built-in Dishwasher Logo
1,252 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
