The speakers and sub are not playing and sound. vs2121 amplified speakers
    Scholar:
  • 141 Answers
What OS are you using sir? Do you have an existing speakers before that worked? try your new speakers on another computer with existing and working speakers. So, that we can isolate the problem,whether of your pc or your speakers.
thanks
Posted on Jun 20, 2008
How do I repair
I guess you have tried switching the speaks left to right to check its the speaker rather than the output to the speaker?
If you have it might be worth (If you are able to) opening up the speaker unit to check the wires are still attached and solid, maybe need a little re-solder is needed as the wires are usually very thin.
Sep 19, 2014 | Altec Lansing VS2121 Computer Speakers
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
A3000DB Car Audio Amplifier: I hooked it up.It played for ten mins. Now no soun...
no, check your speaker wire inside sub box check your ground wire and you might need to wire your subs in series
May 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
When the sub has power to it the speakers play a barely audible radio station. Also if my cell phone is on the desk the speakers play an awful noise. It happens even if the speakers are not connected to...
If you have ATT cell service, this happens when phones get too close to electronic devices. Move the phone away from devices. And when/if you live near a local radio station, or their antenna....a good chance that electronic devices will act like antennas, thus picking up radio signals.
Mar 01, 2010 | Altec Lansing VS2121 Computer Speakers
I can turn speakers on but when I play games there is no sound
try to install your sound (audio) drivers and try to insert the pins in line in ports your work is done...
Jan 20, 2010 | Altec Lansing VS2121 Computer Speakers
I have no audio device can not turn speakers on
Good day heigei, hi if you turn on the speakers but no ON lights came on, the problem is your Speakers' power supply stage, either a fuse opens (most likely) or something got burnt from the plug to the transformer, then to the rectifier diodes (got shorted then fuse opens) or to the regulator section. check also the power switch for poor contacts, of course you may need to open the speakers, If by any chance you hear something like hum.... check for open signal wire, check the IC amplifier also, a bad IC amplifier produce no sound or produce a loud humming/cracking sound. If you have no idea of what im talking about, have it checked by a technician. thats it.
VS2121 no power
Hi , what could of happned is , as you pulled it out , it shorted or caused a power surge ,and blew a fuse of chip in the Speakers, If you still got a warranty Take it back to the shop and ask them to fix it , Do not tell them you pulled the cable out , otherwise they might not offer you your warranty.Hope this helps bud , happy new Year :)
Jan 03, 2010 | Altec Lansing VS2121 Computer Speakers
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
