Question about Thermador Kitchen Ranges
I have a Thermador PCG484EW Gas cook top with two out of four burners that won't light. The 6 Point Gas Re-Igniter module has good voltage going into it from the simmer control so I assumed that the Re-Igniter module was bad and replaced it. The sysmtoms remain the same. I can get any one burner to work by unplugging the others from the Re-Igniter but when they are all plugged in it seams like there is just not enough power to ignite them. Is it normal for several burners to spark when I try to light one? This test also proves that the gas valve is good. Is it possible that I bought a bad Re-Igniter with the exact same sysmtoms or can I be missing something else? My service Tech worked on the thing for a year before I fired him and got involved myself. Can you tell me what Gas Re-Igniter is supposed to be in it. I think he replaced it once himself. Perhaps he bought the wrong one and I replaced it with another one like he bought? The one he put in and the one I put in is a Tytronics Model RI326. Help!! Mike mtschieber@yahoo.com
    Sergeant:
  • 243 Answers
So you say all the ranges will ignite seperatly?
Can you tell me which two wont light? is it the two left Burners?
Posted on Jun 20, 2008
  • Nathan Ayers
    Nathan Ayers Jun 20, 2008
    For proper lighting and performance of the burners, keep the
    ports clean. It is necessary to clean these when there is a boil over or when the burner does not light even though the electronic
    igniters activate.
    if burners dont ignite check the following.
    • Are the burner caps properly aligned on the burner bases
    (Sealed Surface Burners)?
    • Are the burner ports clogged?
    • Is a fuse blown or is the circuit breaker tripped?
    • Is the manual shut-off valve closed, preventing the flow of
    gas?
    • Are the Wok pilot ports clogged?
    • Is the spark igniter sparking (Surface Burners and Wok)?
    • Is there flame on the Wok pilot burner?
    try that and see if there is any result
    Brigadier General:
  • 3,614 Answers
You have to clean your unit.
2 Suggested Answers
  • 110 Answers
SOURCE: Thermador Burners Won't Light
your issue is the potentiometers kit which includes the simmer controller; Bosch redesigned it a couple of years ago due to the serveral issues, the re-lite spark module is RARELY the issue. and yes it is normal on all cooktops for all the burner to spark until you have igniton because the electrodes are wired in series. you may also need a prof. electrician check you pwr source because due to sudden drops in voltage or amperage could cause continuous issues with your liting sys
Burners won't light without lighter
first off let me say that many times oil and food debris clogs the spark igniter holes in the burner. and can be cleaned with a tiny pin or small thin nail inserted in each hole
BEWARE the
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jun 23, 2015 | Ovens
Trouble shoot oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
GAS OVENS
Apr 26, 2015 | Whirlpool Ovens
Zanussi gas cooker gas not coming through no ignition
GAS OVENS
Jul 30, 2014 | Zanussi Ovens
Why won't my gas grill stay lit?
Oven clicks as if it is relighting almost constantly.
Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
GAS OVENS
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Jul 04, 2014 | Zanussi Ovens
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can not hear a clicking sound and the ignitor is not sparking
GAS OVENS
Apr 30, 2014 | Whirlpool Ovens
There is no gas flow to one of the ovens igniters
GAS OVENS
Jan 28, 2014 | Viking 30" Professional Select Built-in...
Oven not working
GAS OVENS
Nov 22, 2013 | Belling Ovens
Diplomat adp 0511 grill has no gas or ignition
GAS OVENS
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Jun 20, 2008 | Kitchen Ranges
Kitchen Ranges Logo
264 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
