Konica 7115 copier
For some reason the copier stuck on 5 1/2 x 8 1/2 under SIZE and I couldn't get it back to 8 1/2 x 11 to make standard copies even though I load all the paper correctly in tray 1. Please help....thx
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Not familiar with that machine, but
most of these problems are simple, usually customer errors
1-some have sensors in the bak of the machine where the tray slides in, remove ray and look for paper in the back
2-is there any slides or something to adjust to say it is 8.5x11?
3-switch trays is it recording the correct size- if yes the sensors are ok
4-take alook at the other tray it is probably set for a different size paper, try switching it to letter and see if there is a difference in the way the trays are
4- it could be set wrong in the menu
5-bad sensors
Posted on Jun 20, 2008
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Oct 16, 2014 | Konica Minolta Konica 7115 7118 Compatible...
I have konica c220 : i print a copy there is ligh green .5 inch line in left side and print copy is redness whats reason?
check the life of the image unit there is no way the transfer belt has this problem...check the image unit yellow and cyan maybe the reason...if you have reset tham the problem is image unit and you need a new one
Mar 13, 2014 | Konica Minolta bizhub Office Equipment &...
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
Oct 05, 2013 | Konica Minolta 950-281 Genuine Konica...
Wrench symbol on Konica 7115 means what?
PREVENTIVE MAINT. Replace drum, cleaning blade,developer etc. comes as a kit for the technicians to replace, clearing counter without doing things not good machine uses the counters to adjust voltage on certain parts and is the only way it knows new parts installed clear counter and not replace parts causes codes and image problems
Jun 25, 2012 | Minolta Office Equipment & Supplies
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
May 01, 2010 | Xerox CopyCentre C118 Copier
Can't get the copier to scan only 8.5*11 area on glass
Set your original settings to the actual size.
You are using the auto recognition feature which is over-ridden when you specify the size manually.
It will try to match it to the nearest size it "knows". That is why the stamp is detecting so large.
Apr 09, 2009 | Konica Minolta Di1610 Copier
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
114 people viewed this question
