Question about Palm Treo 755p Smartphone
Treo 750 p
I kinda of like the phone it is my second treo.
If I talk for more than 10 - 15 minutes it gets very hot. Is this a normal thing? If it is I am on a 30 day trial with verizon and I will take it back and get a different type of phone. My blackberry never had this problem.
If you press both the bottom left button with the large dot and the bottom right 'menu' button, both at the same time, this dims the screen. The screen lumination is the source of the heat.
Posted on Jun 26, 2008
    Problem Solver:
  • 8 Answers
Personally 10 to 15 minutes is not normal, I have had my 755p battery get hot after a couple of hours of straight talking, but not right away.
I would just take it back where you got it and tell them the problem that you are having and get another Treo. I have owned all of the Treo's ever made and they make great phones.
It does take some getting used to but the pros vs the cons of owning a Treo are much greater. Blackberry has come along way with their phones and if you are used to the Blackberry then the Treo just might not be the phone for you.
To get back to your question if the phone getting hot is normal, no, but it will happen from time to time when talking on the phone for long periods of time.
Hope this helps,
Posted on Jun 22, 2008
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
I want to change language
unfortunately you cannot just switch languages on the treo or really any Windows Mobile Treo or Palm
They release the phones with one language installed in whatever country and thats about it.
You can buy a Treo 750 in english, but not change the language
May 28, 2009 | Palm Treo 750v Smartphone
I hv palm treo 750 and it stock on logo
Are you saying the the phone won't turn on or off?
Try to remove the battery out of it and leave it removed for about 10 to 20 seconds. Then put the battery back to the phone.
If you will get the same problem, bring your phone to the authorized
Palm Center. This may need to have a firmware upgrade.
Apr 16, 2009 | Palm Treo 750 Smartphone
Where can I unlock my Palm Treo 750 on Rogers Network
i once unlocked my palm phones using codes from try if your phone is listed for unlocking
Oct 22, 2008 | Palm Treo 750 Smartphone
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
Touch screen not responding
There is a treo repair website that shows you how to replace the screen yourself.
May 04, 2008 | Palm Treo 750 Smartphone
Palm treo 750
try a reset, if that doesnt work, then we can try a hardreset witch also removes all your files from the phone.
If a hardreset doesnt work then the phone is in need of repairs.
Mar 24, 2008 | Palm Treo 750 Smartphone
Treo 750 does not ring
Ok, I thikn I fixed it, but it is kinda dumb. Maybe this will help you. Call your phone from another phone. While the phone is ringing press the Volume Up Button on the left side of your Treo. Now look to make sure that both of the Volume Mixer buttons are turned up. For some reason the system sounds were turned all the way up, but the ringer volume was turned all the way down. The only place that I know to make the change to the ringer volume is pressing the rocker switch while the phone is ringing. Let me know if that helps
Jan 21, 2008 | Palm Treo 750 Smartphone
Palm treo 750
i think you get the option to choose your language after a hard reset? if you wish to do that. make sure you have done a hotsync
Dec 30, 2007 | Palm Treo 750 Smartphone
Syncing of palm times out
this is producers mistake :(
Sep 23, 2007 | Palm Treo 750 Smartphone
Palm Treo 755p Smartphone Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
