Question about Mitsubishi VS-45609 TV
Mitsubishi ws-65513 Hi, my mitsubishi would shut off every now and again and the light would flash for a minute before you could turn it back on. One day it just didn't come back on. Now if I plug it in the light just flashes non stop and the reset button does nothing. I was wondering if you could send me a repair manual and schematic if available. Also suggestions would be helpful Thanks joldfield@knology.net
    Sergeant:
  • 233 Answers
Done.. its in your inbox!
Posted on Dec 20, 2008
WS-65513
mike, give me an email address and I can send you a PDF!
Dec 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
You need the DM repair kit if your power light is blinking and doesnt stop. Go to this link and look under the catagory section on the left side and click on repair kits. You need the V23 DM kit . It has the replacement parts , plus the detailed instructions with pictures and the full service manual and schematics manual on CD and it cost less than you can find just the service manual anywhere else. Heres the link.
http://servicemanuals.vstore.ca/
Jun 20, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513 won't turn on
Probably blue a fuse in back is what you saw. But something caused this to happen. You can replace the fuse but something else is probably damaged. For more info ctechnicians.com
Jan 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi VS-45609 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
